They are the same fault - P0101 is generic code, 4795 VW's own code for the fault.
4795 - Mass Air Flow Sensor (G70) - P0101 00 [101] - Implausible Signal
Intake air leak?
Might be helpful to see what engine it is - please post "Detailed ECU info"-report (under Carista Service menu)
A Transporter case with the same fault code.
T5 Intermitant Boost Issue HELP struggling
T5 Had a new egr just fitted but still some faults remain 4795 - Mass Air Flow Sensor (G70) BUT brand new unit fitted also. 5171 - Boost Pressure Regulation ? Fault is very intermitant only seems to do it once a day Friday,10,May,2019,10:56:10:43739 VCDS -- Windows Based VAG/VAS Emulator...forums.ross-tech.com
ECU info obtained with Carista 6.3 for Android:
VIN: WV1ZZZ7HZGH04****
Engine
Part #: 03L906019JP
Component: R4 2,0L EDC
Software version: 8439
ASAM/ODX identifier: EV_ECM20TDI01103L906019JP
Coding: 01254012232401080000 (hex)
Fault codes:
04795 Manufacturer-specific code
Transmission
Part #: 0BT300045T
Component: DSG DQ500-7F
Software version: 2401
ASAM/ODX identifier: EV_TCMDQ500021
Coding: 0014 (hex)
[No fault codes]
ABS
Part #: 7E0907379P
Component: ESC
Software version: 0132
ASAM/ODX identifier: EV_Brake1ESCCONTIVN75XGP2
Coding: 557E409825668484AA7E0279A48821E6390000 (hex)
[No fault codes]
Instrument cluster
Part #: 7E0920970L
Component: KOMBI
Software version: 1008
ASAM/ODX identifier: EV_Kombi_UDS_VDD_RM09
Coding: 7709010100 (hex)
Fault codes:
13654544 Manufacturer-specific code
Airbags
Part #: 7E0959655D
Component: VW10Airbag00J
Software version: 0016
ASAM/ODX identifier: EV_AirbaVW10BPAVW12X
Coding: 00000000000000000000000000000000304A (hex)
[No fault codes]
Steering angle
Part #: 6R0959654
Component: LENKW.SENSOR
Software version: 0070
ASAM/ODX identifier: EV_LWSKLOVW25X
Coding: 01 (hex)
[No fault codes]
Parking/steering assist
Part #: 7E0919475N
Component: PARKHILFE 8K
Software version: 0205
ASAM/ODX identifier: EV_VW75XParkAssis8K
Coding: 10810C (hex)
[No fault codes]
Heater & air conditioning
Part #: 7E0907047T
Component: Climatic-T5
Software version: 0607
ASAM/ODX identifier: EV_ClimaticT5
Coding: 0000000003 (hex)
[No fault codes]
Radio
Part #: -----------
Component: Radio
Software version: 5814
ASAM/ODX identifier: [none]
Coding: 16000440040000 (hex)
Fault codes:
00872 Bass Speaker Rear Left (R15)
00873 Bass Speaker Rear Right (R17)
00876 Treble Speaker Front Left (R14)
00877 Treble Speaker Rear Left (R16)
00856 Radio Antenna
02873 Control Module for Camera Reverse Driving (J772)
Central electronics
Part #: 7E0937090
Component: BCM PQ25 Max4
Software version: 0733
Coding: B8AC393A0AF3349193284F747CEB8E748FA0710F60CC6D60320400230800 (hex)
Fault codes:
03303 Feedback Locked-Position rear-left
02746 Right daytime running light (DRL) lamp
CAN network gateway
Part #: 7E0909901
Component: GW-K-CAN TP20
Coding: 042305 (hex)
Fault codes:
03158 Control Module for Information Electronics 1 (J794)
Immobilizer
Part #: 5K0953234
Component: IMMO
ASAM/ODX identifier: EV_Immo_UDS_VDD_RM09
Coding: 000000 (hex)
[No fault codes]
Battery regulator
Part #: 7E0907534
Component: Batt.regelung
Coding: 030B1A73 (hex)
[No fault codes]
Infotainment system
[ECU not present]
Sorry so what does this mean please don't say turboThanks. So it's EU5 CAAC engine thus the same family of engines as the linked example (CAAA).
It was just the information extracted from the Carista report so members having the same/similar engine could contribute.Sorry so what does this mean please don't say turbo
Ok will try looking there first at hoses what do you mean on charge air cooler ? SorryIt was just the information extracted from the Carista report so members having the same/similar engine could contribute.
I would start by checking for an air leak. Loose/split air hose, charge air cooler, etc.
Ok do you mean replace air cooler as wellHere are the charge air system pipelines of CAAC engine. Charge air cooler is #1.
Source:
@mmi wrote charge air cooler not change air cooler.Ok do you mean replace air cooler as well
Ok this is all losing me well over head haha maybe time to hand to garage and let them sort it@mmi wrote charge air cooler not change air cooler.
What you have there is often referred to as the intercooler, on the 204ps there is a charge air cooler, does the same job but water cooled not air cooled.
@mmi was just saying check the system in the diagram for a leak, it contains pressurised air when the engine is running, higher the RPM the higher the pressure. I will probably make a whistling noise if leaking.Ok this is all losing me well over head haha maybe time to hand to garage and let them sort it
Ok great thank you sorry don't know much with engines and was just lost with what to do . Iam builder give me house no problem give me engine it all over with haha and yes you are right I have had soft whistling sound for a while I thought it was just turbo thick yes I know lol@mmi was just saying check the system in the diagram for a leak, it contains pressurised air when the engine is running, higher the RPM the higher the pressure. I will probably make a whistling noise if leaking.
Thanks for letting us know - really appreciated!Hi all thanks for help all sorted today was a split cooler new one fitted hey presto sorted
Did the garage say if it was stone damage?Hi all thanks for help all sorted today was a split cooler new one fitted hey presto sorted
Never said he showed me old one and it was fair size hole he said he would of thought it was on way out for a while and then just went , but does drive completely different now and seems a lot quieter so how I never noticed I don't knowDid the garage say if it was stone damage?
