Engine management light
VioletVW
So, the management light pinged on Sunday while out. When I got home, I scanned for the error codes and here is what I found:
PXL_20230911_192302119.jpgPXL_20230911_192307425.MP.jpgPXL_20230911_192310237.jpgPXL_20230911_192313150.jpg
Seems like a long list of electrical faults. I've no idea if they are serious, but at the moment neither does VW....
I called the local dealer to be told I cannot be seen until 16th October?? They suggested phoning VW Assist, which I then did. Assist insist that because the dashboard light that is on is not red, but amber, then it's perfectly safe to drive. Seems odd to to fob off a problem without at least someone from VW scanning the vehicle to ensure that the fault is not serious. Apparently, this is their protocol now and my van is safe to drive, every day, for the next month...
Not the service I would have expected for VW.
Van has finally been looked at and apparently it was an ad-blue mixing valve...which didn't come up in the list of things above. Hopefully, it's now cured.
