T
Picture attached.
I’ll take it steady on way home and call breakdown if the engine light comes on.
Does anyone know of possible problems of running with a split intercooler?
Hopefully if I keep turbo load low it will be ok!
That’s a job for me for next week, but so good to have identified what it is! Thanks @cy294
Great, thanks so much for sharing the photos, and you were absolutely right…. Problem now diagnosed!! Definitely a shot intercooler, and actually sooty residue over bumper.Hi, sorry for the late reply. I am assuming that your T6 is a single turbo version. It is more likely to be the intercooler.
If you look through the grills at the front, you should see two radiators. If you look at the one closet to the grill, you maybe able to see that the fins or structure of the rad which is smaller than the one behind has failed and has essentially collapsed. If so, it is causing power to be lost and the engine to overboost, which is the whooshing noise.
It may cause the van to go in to limp mode, have an engine management light warning light or loss of power.
I drove mine round for ages and didn't notice anything until I just happened to have the window opened fully and was pulling away from traffic lights and that was when my attention was drawn to the sound. I reckon it was like that for several weeks even months.
It will probably need a new intercooler if you have the same version as mine. I have posted some pics of the faulty intercooler I changed yesterday and the fact I had to take the front bumper off. Sounds worse than it actually is.
Good luck and safe journey home and if you need more info, just DM me if you want.
Picture attached.
