I know the LEDs don't because there is a setting in the DIS to swap them. Does the H7 have this, otherwise I guess a film is needed.Is there a H7 version ?
I was under the impression modern lights don't need the headlight adapter films
That's for LED lights. If you think about it, you can't change the beam pattern from a reflector, which is why you need to block some of it out with a sticker.
Does your 6.1 have this function? I can’t find it on my 6.1 but definitely used it on the T6. I thought it had been omitted from the 6.1.I know the LEDs don't because there is a setting in the DIS to swap them. Does the H7 have this, otherwise I guess a film is needed.
No, the OP has a T6.Does your 6.1 have this function? I can’t find it on my 6.1 but definitely used it on the T6. I thought it had been omitted from the 6.1.
Just shove some stickers on to keep “Les flic” happy!No, the OP has a T6.
IIRC the T6.1 LEDs have a flat beam pattern, so they do not require adjusting or stickers for travel to Europe.
Also works! Saves all that wd40 getting the glue off when you get home!!!Or better yet just shove them in the glove box and wait til you’re stopped to say oh pardon I do have them but completely forgot… they’ll be in there for years![]()
