Well done, i took the seats out completely as it made my life a little easier to remove things. Also you can remove the B pillars and pull through the plastic tubing used for wiring.
Just make sue the van is on level ground and in gear as when you disconnect the handbrake there is the potential of the van moving.
The cigarette charger on the lower housing passenger side with a 12v sticker next to it I also removed. At some point this will go into the centre port on the dash.
The strip lights I removed completely, looking to reuse and put all three in the back via leisure battery etc.
You may find that if you remove the stereo(easy to do)there could be some cables tucked in behind that have been cut.
As for the Fuses, i took the both out and put to one side, as not knowing 100% what they are for….poss tow bar
As for the positive’s, on mine one was fed via the front wing to the battery, the other was under the floor.
Once finished you could be left with 2 piles like in the pics of waste.
Hope this helps?
