Just have to find a way into the cabin in order to place a switchI have a H7 module on mime. Wanted to hook up a 20 inch bar on a license plate bar. Stressed til I found this site...Plenty of handy tips here. Ended up using Stedi VW amarok high beam piggy back with a smart wire harness and it works a treat.
VW Amarok Headlight Piggy Back Adaptor
Eliminate the need to splice and or solder your vehicles factory wiring with our piggy back adaptors. Please note that this listing is for the piggy back adaptor only. Wiring Harness Sold separately.www.stedi.com.au
Single Connector Plug & Play SMART Harness™ High Beam Driving Light Wiring
If you have ever wonder how to wire you LED Driving lights to your High Beam, STED's new Quick Fit Driving Light wiring harness makes installation as easy as 1, 2 3.www.stedi.com.au
To be able to switch it off so I can just use the van's own high beams.Why do you need a switch?
I can't think of any situation where I wouldn't want maximum light on main beam.To be able to switch it off so I can just use the van's own high beams.
Thanks for the tip yvikash. Just ordered same harness with dual plugs. I've got a couple 12" LED bars going into my bullbar. Will see those damn Roos from a mile away!I have a H7 module on mime. Wanted to hook up a 20 inch bar on a license plate bar. Stressed til I found this site...Plenty of handy tips here. Ended up using Stedi VW amarok high beam piggy back with a smart wire harness and it works a treat.
for T6.1
Thank youHi.. @jedistar I had this switch fitted for my DRL ( separate switch due to already having Led lights ) it’s a cheap push switch
This is similar…
