I can shut windows, close sunroof & fold mirrors on me lock button!
Really? I did note that there was a ‘convenience ‘ setting on the sunroof.You should be able to do all that in reverse too.
I'm sure you'll find TS meant you should be able to from factory because you can't actually open the mirrors from a fob without an aftermarket modification. The tailgate should also be on the fob from factory but isn't.Really? I did note that there was a ‘convenience ‘ setting on the sunroof.
I’ll try this out soon. Vans’ at the converters at the mo for a bit of work. So I’ve not really had time to check it all out. Ta for that info Tourershine.
That’s how I read it TS. I’ll try this when the vans’ back.I meant you can drop the windows, and I'm sure open the sunroof by holding down your unlock button.
But you can't reverse the mirrors on the fob??? So saying you should be able to reverse them all isn't correct. Had you said just the 2 I'd have agreed.I meant you can drop the windows, and I'm sure open the sunroof by holding down your unlock button.
Of course you did but others reading it would have thought the feckin' mirrors opened too on the fob so I was merely correcting it. Nothing pedantic about it in the slightest.Thanks Mr Pedantic, I knew what I meant.
if its setup for comfort closing . . . then pressing and holding (about 5 seconds) the lock button on they keyfob should tilt them up. (when you lock the van)Is there a way of checking if I have folding mirrors fitted. The switch I have fitted doesn’t have the folding mirror icon but I have been told they still have the motor fitted. My is an 18 plate Caravelle exc.
This is not true. VW are not going to fit powerfold mirrors if you haven’t spec’d them.Is there a way of checking if I have folding mirrors fitted. The switch I have fitted doesn’t have the folding mirror icon but I have been told they still have the motor fitted. My is an 18 plate Caravelle exc.
Bought it as an ex demo, so I guess it’s a missed opportunity. Anyone used the travellin lite onesThis is not true. VW are not going to fit powerfold mirrors if you haven’t spec’d them.
