Sold Factory leisure battery
Brennanpj
Factory supplied leisure battery , as new just removed from van with 1k on the clock .
VARTA 75ah
Not sure of its value !?
Would have gladly taken it, but too far unfortunately. You don’t travel at all do you??
I’m near Manchester, but will be in Bath on Tuesday!
Worth a shot!
Hi , I don’t go far I’m afraid . You welcome to bypass Bicester & collect it on your way to Bath!!
I’m a leisure battery noob.
I have the wiring to plumb it in under passenger captains chair. Is it easy enough to wire it up for say phone chargers etc? Been meaning to do it a while for people on bench in row behind
I’m a bit of a leisure battery noob myself, but if you have some wiring to connect this to the van already in place ? connecting from battery is the easy bit . You will need a small fuse board for all your 12v / usb stuff to connect to. Then onto one of the fuses you can see in the picture.
