Factory swivels are in the seats, thats why you lose the height adjustment. I have read on here that it is possible to retro fit.I believe the bases are fixed to the floor with 4 bolts and then the seat is fixed to the base with 4 bolts
Right, sorry I misread the question. I thought it was just about swapping the seats. That makes more sense!Factory swivels are in the seats, thats why you lose the height adjustment. I have read on here that it is possible to retro fit.
Thank you for the reply. I’m searched here but can’t find anything..Right, sorry I misread the question. I thought it was just about swapping the seats. That makes more sense!
Yes, the swivels are in the seats. I believe someone on here tried to retrofit the swivel to a different seat but not sure if they were successful
Not a daft question at all. Hmm didn’t think of that. I will look into it.Possibly daft question but if the aim is to gain heated seats I assume your van has the wiring in place for that or you have a plan?
Thank you.I took out my height adjustable base and swapped it with a factory swivel.
Pretty straight forward. Not many bolts.
Remove the seat base 4x bolts, back rest 4x bolts and swap. The seat base only uses two bolts though and has a bit that slides in instead for the rear ones. Plastics are different
Would you be willing to sell me the height adjustment base please ?I took out my height adjustable base and swapped it with a factory swivel.
Sold a long time ago I'm afraid along with the donor seat. Sorry.Would you be willing to sell me the height adjustment base please ?
Thanks dudeSold a long time ago I'm afraid along with the donor seat. Sorry.
Usually some on ebay.
Would you know if the T5 height adjustment base would fit a T6.1 seat ?Sold a long time ago I'm afraid along with the donor seat. Sorry.
Do you by any chance have a list of part numbers required to swap to factory swivels?I can't be sure, sorry. I know they changed the slider handle. Not sure what else. They look the same mounting points but wouldn't like to guess.
