Faulty LED grille DRL
Base1388
Romany - Plumber
Hi all.
As above. Condensation in the lens.
What can I do?
No idea of cause.
Are they genuine VW?
I had condensation in one of my front fogs, after I changed to LED bulbs. Transporter HQ swapped the bulb incase it was a faulty seal, but it still fogged up. I used a heat gun to gently warm it up, and it's never condensated since.
Bare in mind that I could remove the bulb to allow for the moisture to escape whilst warming. I'm not sure if that's possible with a Drl if they are a sealed unit?
Yes the genuine VW.
Bought from here. Forum shop !
As a sealed unit I wouldn’t expect it to do that ?
Should I try warm it up ? But as you say moisture has no where to go.
I’ve never used a jet wash so I’ve not forced moisture in there.
Just appeared
Yes the genuine VW.
Just appeared
Maybe give it a few days. My wife's new Mini headlights had condensation from new, but it eventually disappeared and never came back.
@Pauly
Hello Sir, hope all well
This DRL thing is worse now !
I'll post a picture in a min.
Are you at Camper Jam ?
Just wondering if it possible you could bring a replacement for me ? Don't know how forum shop returns normally work, I just didn't want a hole in my bumper while I waited for a replacement.
Please let me know anyway
Many Thanks
Try your local dealer, the warranty is with VW if they are faulty they will replace them
Hi everyone. I’ve got a bit of a problem with flickering lower DRLs on my T6. Anyone ever experienced this. They are factory VW ones and both are doing it in sync.
