F45s has arrived but no brackets yet can't wait to get this fitted, will make over night stops a lot easier and saves me having to bring a awning with us , anyone use the front and sides that clip on is it called a privacy room ? @Loz think I seen at bala you had one of these do you rate them ?
Looking to get a Fiamma F45S for the caravelle, emailed justkampers about the brackets but the response was not helpful (“comes with standard brackets”!) I want to use the bolts in the roof channel so not sure if I have to buy the awning with standard brackets and pay on top to get the correct ones or if I can spec the correct ones at the time of purchase- can anyone enlighten me?
just got a sh awning with VW brackets - is there an adaptor code for the piece I need to fit it to my transporter which has sliding multirail / c rail fitted and which allows me to keep Thule aero bars still on top..... it is the caravelle? Rails that the roofbars Slide up - not fixed points.
Evening, bit confused about what I should be looking to buy.
I have a T6 panel van and it will be getting a Denby pop top. I also want to fit a Fiamma F45s. There is mention of a C rail being needed ? What is this? The F45s brackets screw and glue into the fix point mounts on the roof I believe so why is a C channel needed?
Does the F45s come with the brackets for a C channel.
I'm really confused.....
