Fitting 2nd Row Seat Brackets so I can move my Kombi Bench back
Hoping to breathe a bit of life into this thread as its the closest I've seen to what I want. Hopefully be getting a T6.1 in the autumn with the plan of turning it into a day van/camper for the following spring. So many ideas so please bear with me.
It's going to have to have 3 full size seatbelted seats in the back, no RIB or rock n roll. As further up in the thread states position '2.5' is unsuitable due to mounting spacing and seat belts, so my question is.... how difficult are the seats to move? Is it possible to have normal driving position like a kombi, park up, pop the seats back a notch, spin the front seats and have a useable living space.
Alternatively, has any fitted non-vw seats. Ford tourneo for example with the intergrated seat belts in position 2.5?
Great thread by the way
Hi Phil, welcome!
Yes you are correct position 2.5 is not possible with a SWB. I have seen it done in a LWB though but not something I have experience with myself as I have SWB. Are you getting a factory Kombi or panel van?
When you say 3 full size seats what do you mean exactly? the Kombi Triple bench seat? or the shuttle 1+1+1 single seats.
The triple Kombi bench is heavy! I can move it on my own between position 2 and 3 and its doable just a bit awkward wouldn't want to be do be doing it multiple times a day. I have the third row brackets and seat belts installed on my van (as detailed earlier in the thread) as we tend to move them back on holiday or if out and about for the whole day etc. It does indeed work really well and give you a really good useable living space. With the seatbelts you can of course travel with passengers in the rear and the boot is still bigger than most cars. Much cheaper than a fixed or sliding bed!
only downside is if you don't have rear quarter windows the passengers in the rear cant see out. not a major issue really and you could always get windows installed if you wanted.
Look forward to seeing how you get on!
on a another note.....
If you are getting a panel van I would seriously consider the caravelle rail system. Yes its going to be more expensive than the kombi seats but the kombi seats have got really expensive recently so its not the difference it used to be. That's the setup I ultimately want, then you can just slide the bench back to any position you want really easily and also have the option of additional single seats.
Thanks for getting back to me. By 3 full sized seats i mean something that would sit 3 prople comfortably. Was looking at the 2+1 set up. When you say 2.5 is not possible is that down to no seat belts and a longer distance between mounting points? It would never be used as a driving position, just when camping ir parked up for the day. Hadn't even considered rails, would solve all of my problems really. I'll hopefully have about 20k by November so would rather spend it on a decent panel van rather than pay the extra that comes with a kombi. I consider myself to be a handy youtube DIYer so will be giving most things a bash myself
So after a lot of head scratching I think I'm just going to put a 3 seat bench in the 3rd row. Caravelle rails would be ideal but for the price difference I don't think it makes sense. The kids rarely look up from a screen on a long journey anyway.
Should be looking to buy early Nov and spend the winter getting it usable for the spring. Just going to spend the next few months scouring these threads for ideas. Thanks @david173 for your advice
I'm actually after just moving the existing seats back when I go away for the weekend, my front seats are on a swivel base but the current position of the back seats is a little too close
I've also got a bed which sits on the back of the bench seat and it would be great to have that further back in the van
Hi, can I ask what the bed is? I’m wondering if my amdro will work if I move bench back.
Anyone recommend a garage who would do this, North or Scotland would be best, Cheers.
I've asked two conversion garages in central Scotland and both said no, they only fit RIB there :/
I built a frame out of 3"X2" and popped some old bed slats onto it so it was completely level with the back of the seats when folded down - it's about 6' long in total, then I got 2x 2'6" foam mattresses - I leave the bedding on and it means I can change from seats to bed in a minute
It also gives me a pretty decent garage for all sorts of junk :slow rofl:
These guys did mine - would recommend
sounds great!
sounds great!
I got the wood from B&q for about £20 and knocked it together in an afternoon
It's not the most elegant solution but I've been happily using it for a couple of years now as I couldn't afford anything else at the time
With the frame and the back of the seats if gives you a solid base for the mattress and folds away quickly
i did similar in my old panel van t5 for a lift out bed base. worked great.
