Hi All,
I know this topic has been raised across several Transporter forums but I havent been able to find all the info I need I have a swb T6 kombi I am going to remove the rear bench seat and fit the caravelle rails i have a set of double rails the ones that allow you to have the table I understand what work is involved to fit them I work in the engineering profession so feel confident to do it and have done similar on different vehicles the information I am looking for is which and how many reinforcing brackets I need?
The rails I have have came with the proper bolts there are 5x in each of the outer rails and 7x in each inner rail I've seen a couple of types you can get online (I do intend to get genuine VW ones) has anyone got any photos of the underside of a T6 with the rails fitted or even illustrated parts catalogue?
I just want to make sure I have all the parts ready before I start rather than strip it all to bits and realise I dont!
Stuart
Same here m8 banwy only 30 miles from meThanks Andy, I'll give Banwy a call as they're local
Hi @Wills mine used 24x bolts in total 5x on each outer rails and 7x on each of the inner rails.
The link below are of the reinforcing brackets I used they are left & right handed I used 6x of each hand
#092 GENUINE VOLKSWAGEN T5 TRANSPORTER REAR SEAT REINFORCEMENTBRACKETS
And I used 2x of the larger brackets
Reinforcers Kombi Caravelle Seats
tps can supply all the parts and probably cheaper than banwyI'm a little further away in Hawarden Andy, worth me paying a visit?
Thanks @Coradia63. Banwy appear to be cheaper than ebay for the smaller brackets. Where are the larger and smaller brackets required to be fitted please? You've used 24 bolts and 14 brackets?
TPS Chester 7.3 miles from your location
Unit 4, Jupiter Drive, Chester West Employment
