Hello all. I have an update to finish off my install.
On the last Monday of March I drove down to Propex Leisure in Ringwood to get the LPG tank, heater and BBQ point installed.
I was feeling super confident as I booked the van in and handed over the keys. Let’s just say it was short lived! So short in fact that the cup of coffee they’d made me as I arrived hadn’t even touched my lips when the chap came out of the workshop and said “well your clever idea isn’t gonna work!” Perhaps it’s just as well that I hadn’t taken a sip of coffee or he may have got covered in it.
Got out to the workshop and saw what he was on about. Ultimately, because the inlet and outlet for the Propex heater are both on the same end, it wouldn’t fit between the OEM ducts under the van.
I asked why the unit had to be mounted exactly there, could it not be moved off centre or some other arrangement. The answer was no as this is where their bracket is made to fit. Ultimately as this is a bespoke fitting to equipment that makes it look OEM inside, this was not the answer I really wanted. However, after lots of head scratching a plan was hatched.
The warm air outlet could fit on the duct that passes up into the b-post, and this is the most important to be as straight in line as possible. I had to remove the rubber connector from that duct, and mounted the 90-60mm plastic reducer directly onto the duct.
However, to do this meant that the front OEM duct had to go. I keep telling myself that it’s ok as this about getting the heating system I want with the right look inside the van.
This left me with a hole in the step where the duct was originally ported. So made a panel that was bonded and riveted in place over the top.
In order to get the air recirculation duct work in behind the grill in the OEM step i’ve had to use some bits and bobs from Propex to achieve this, which then runs in above the heater unit under the van, which then curves round to connect to the unit.
