Bingo, cheers DuncanI've not got heated seats, but I have swapped my heater controls for one from an old golf so I now have a heated rear window switch. Only 1 wire from the BCM to the rear screen and coding needed.
Well @Pauly and @Ads_Essex i started removing the front double seat and accessed the heated seat pad.I believe the double seat has individual pads so you may be able to reuse 2 of the four existing pads in a single if they are the correct shape/size
Think it would be a trial and error process though to see if they fit unless anyone else has already tried
I would be interested in any left over pads if you do end up removing them
They could be ok as a separate option, not sure how they would interact with the vw 3 stage heated seat button?I have been looking into this, now winters here.
This seems a good product, had some great reviews on a LandRover forum and the switch control looks good too.
DA5717 | Retrofit Insert Seat Heaters | Britpart
Spotted a kit on Ebay that looks reasonable, may pull the trigger.
Land Rover Heated Seat Kit Retrofit Inserts for 2 Seats DA5717 Britpart | eBay
SB
That’s a shame.Well @Pauly and @Ads_Essex i started removing the front double seat and accessed the heated seat pad.
Unfortunately it’s just the one pad across the bottom. Was hoping for four pads, two top, two bottom.
Will have to buy aftermarket heated seat pads to fit in my new single!![]()
I spoke to the guys over at Hazzydayz who do heated seats with original parts and they said best thing to do if (in my case) is to speak to vw and they should supply new mats.That’s a shame.
My upholsterer told me that the section in the base of my drivers’ seat looked burnt out so I’m in the market for a replacement - if you find a set (for two singles) at a reasonable price then I’ll go halves with you, if that suits.
You wouldn’t happen to have the part numbers would you @Pauly ?Think you are looking around £100 a pad for OEM units
Thank yoooouuu!!There are loads mate can’t quite figure out which is which I will post a pic later with some part numbers for you to have a look at
Thanks mate..! Will go through this and see what Vw says tooHere you go
Assuming you need parts 1 & 10 there are a lot of options !?!?
Now I didn’t notice parts 50 & 51 today.? Or 40 & 41? What do they do??Here you go
