rstaunton18804
Hi all,
I know there have been a few threads regarding flashing coil and most following the process of (1. replace oil pressure sensor,2. check wiring, 3. oil/filter change, 4. oil pressure valve change). I'm currently at stage 3.
In my case is the coil light has come on immediately following it being with a converter for two months. The light comes on as soon as higher revs are required, will turn off when you restart, and will not reappear if you restart once the van is already warm.
I wonder whether anyone might have any particular thoughts on why this error would arise following a van having been worked on in the following ways-Full leisure battery, diesel heater, underslung water tank around spare.
Last thing I need after a pricey conversion is to spend a mountain trying to fix this oil issue-all thoughts appreciated!
