Hi folks, this has been discussed before!
Eyup folks, hope you’re all ok.
Similar problem to last time, but this is where I’m at now, I’m running out of ideas and money, my guy who looks after my van hasn’t come across this problem either.
Coil light flashing /Start stop error , plugged in and needed an oil pressure switch, had this fitted,
Two weeks later coil light flashing again, won’t rev over 3000 rpm when driving until it’s warm and you turn off and on again, then it’s fine for the rest of the day.
Plugged in, it’s saying oil pressure switch again, there’s two of them on this van so fitted the second one today .
Coil light still flashing Start/stop error on dash and same problem again, plugged back in, still says oil pressure switch, but obviously they’re all replaced.
Saw on here someone who had this problem then fitted an oil pressure regulator valve . Fitted this!! This fixed theirs but mine still doing it?!
Anyone had this or have any ideas?!!
Apologies for long boring post!!
Fault code always P164B
T6 150 2016 (66)
T6 150 2016 (66)
