Hi all
I’m mounting a flexible solar panel to my pop top. The pop top has a ridge down the middle so I’m thinking of using the ABS corner pieces usually used to mount rigid panels. I’ll add countersink screws to the corners, my solar panel has 4 holes, 1 at each corner and bolt the solar panel down after fixing the corner pieces to the roof using the usual sealant method.
Anyone else used this method?
