Hi,
I've got a T6 fitting with a 110Ah AGM battery. This is then connected to a fusebox via 2 x 70amp cables (plus and minus). To the fusebox I have amongst other things 6 x LED's and a Webasto Air Top 2000 heater connected. The LED are fine, they work as curtesy light and can be switched on "manually" from a switch in the back. Only issue is now that when the heater starts up / cools down the LED flickers... Having read multiple post at various VW fora, it has been sugested it could be a voltage drop and yes, there is a slight drop when the heater starts up (around 0.3V), but that does not explain the flickering. Others have sugested it have something to do with the fuel pump and back EMF from the coil in the pump... So far, I have found no one that has cured this issue. As a side note, I also have a flexible stalk LED reading light fitted to the fuse box and that seem to not be affected at all.
I am hoping one on all you people here has come up with a solution, and would be grateful for any comments.
Regards,
Henrik
Regards,
Henrik
