Br/ws is the chassis ground via the main loom...
You should have less than 5ohms to ground.
The pump should show voltage across the two terminals when engine running.... 12v-14vdc.
With that meter... you should read this with reference to ground....with loom connected.
Could you change the measuring range to AC (instead of just DC) to see if you get "proper" readings also then. Just thinking that most modern sensors are transmitting data instead of steady DC voltage levels. If you had a multimeter with frequency metering that would definitely reveal data transmissions.This is what the 3 sender unit wires are reading.. all the same.
It’s on the fuel2 drawing you posted earlier, brown/yellow G17
Oh yeah...... didn't even realise...It’s on the fuel2 drawing you posted earlier, brown/yellow G17
I wonder if it one of the earths on the earth point behind the instruments or the instruments control unit itself?
Yeah I did but couldn’t work it out?Its sounding like the 410 earth point is bad then....
Should be fine doing what you suggested.... you would in effect just be adding a second body ground (0v earth) to the 410 loom wire....
Did you look at @Loz link above for the earth point locations?....but you can re-earth anywhere on the 410 line.
