Monday,23,November,2020,09:10:30:26804
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64
VCDS Version: 20.4.1.0 (x64)
Data version: 20200331 DS317.0
www.Ross-Tech.com
VIN: WV2ZZZ7HZGH04xxxxx License Plate:
Chassis Type: 7H-VN75 (7E0)
Scan: 01 03 04 08 09 15 17 18 19 25 37 56 61 69 0B
VIN: WV2ZZZ7HZGH0xxxxx Mileage: 27770km-17255miles
01-Engine -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
04-Steering Angle -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: Malfunction 0010
15-Airbags -- Status: OK 0000
17-Instruments -- Status: OK 0000
18-Aux. Heat -- Status: OK 0000
19-CAN Gateway -- Status: Malfunction 0010
25-Immobilizer -- Status: OK 0000
37-Navigation -- Status: Cannot be reached 1100
56-Radio -- Status: Malfunction 0010
61-Battery Regul. -- Status: OK 0000
69-Trailer -- Status: OK 0000
Address 01: Engine (2D2D2-CXHA) Labels:. 04L-907-309-V2.clb
Part No SW: 04L 906 056 KM HW: 04L 907 445
Component: R4 2.0l TDI H02 6186
Revision: 23002001
Coding: 0019401C430401090000
Shop #: WSC 02737 790 50316
ASAM Dataset: EV_ECM20TDI03004L906056KM 004013
ROD: EV_ECM20TDI03004L906056JS_004.rod
VCID: 020B54C69567A5961D-8056
No fault code found.
Readiness: N/A
Address 03: ABS Brakes (J104) Labels: 7E0-907-37x-MK100ESC.clb
Part No SW: 7E0 907 379 P HW: 7E0 907 379 M
Component: ESC H05 0132
Revision: 00000000 Serial number: 42505000001532
Coding: 307E40982566847E0C7B027CA48221D3790000
Shop #: WSC 02739 790 50316
ASAM Dataset: EV_Brake1ESCCONTIVN75XGP2 011001
ROD: EV_Brake1ESCCONTIVN75XGP2_011.rod
VCID: 3F8D9D32A615087E32-806A
Address 04: Steering Angle (G085) Labels:* 6R0-959-654.clb
Part No SW: 6R0 959 654 HW: 6R0 959 654
Component: LENKW.SENSOR H07 0070
Serial number: 26061504650890
Coding: 01
Shop #: WSC 00000 000 00000
ASAM Dataset: EV_LWSKLOVW25X 005001
ROD: EV_LWSKLOVW25X.rod
VCID: 7EF32036E19FC17679-802A
Address 08: Auto HVAC (J301) Labels:| 7E5-907-047.clb
Part No SW: 7E0 907 047 R HW: 7E0 907 047 R
Component: Climatic-T5 H22 0607
Revision: 00001002
Coding: 0000000003
ASAM Dataset: EV_ClimaticT5 A01003
ROD: EV_ClimaT5Basis.rod
VCID: 3979F32AB831264E0C-806C
Address 09: Cent. Elect. (J519) Labels:. 7E0-937-BCM-V1.clb
Part No SW: 7E0 937 090 HW: 7E0 937 090
Component: BCM PQ25 Max4 H80 0736
Revision: B9080001 Serial number: 0771 246150901
Coding: A0F4793A0A231493922849642E0B9C548D84698960440970320400BF0840
Shop #: WSC 43013 002 104857
VCID: 68DF666E9B1B6FC6A3-803C
Subsystem 1 - Part No SW: 7E0 959 801 K HW: 7E0 959 801 K Labels: 7E0-959-80X-V2.CLB
Component: J386__TSG_FT 003 8654
Serial number: KU0KU027081552393158
Coding: 1400B0
Subsystem 2 - Part No SW: 7E0 959 802 K HW: 7E0 959 802 K Labels: 7E0-959-80X-V2.CLB
Component: J387__TSG_BT 003 8654
Serial number: KU0KU007091552501498
Coding: 0400A0
Subsystem 3 - Part No: 7E1 951 171
Component: DWA-Sensor 00 001 0104
Coding: 000000
Subsystem 4 - Part No: 1K0 951 605 C
Component: LIN BACKUP HO H05 1501
Coding: 000000
Subsystem 5 - Part No: 7E1 951 171
Coding: 000000
Subsystem 6 - Part No SW: 7E0 959 442 HW: 7E0 959 442
Component: E221__MFL-DC1 H02 0103
Serial number: 39170002737200037506
Coding: B0FFFF
1 Fault Found:
50990 - Unknown Error Code
Unknown - 014 -
Freeze Frame:
Fault Status: 01101110
Fault Priority: 2
Fault Frequency: 1
Reset counter: 67
Mileage: 27773 km
Time Indication: 0
Date: 2020.11.23
Time: 09:02:57
Address 15: Airbags (J234) Labels:| 5K0-959-655.clb
Part No SW: 7E0 959 655 E HW: 7E0 959 655 E
Component: VW10Airbag00C 008 0016
Revision: -------- Serial number: 003PJ000EW8F
Coding: 000000000000000000000000000000003043
Shop #: WSC 02734 790 50316
ASAM Dataset: EV_AirbaVW10BPAVW12X 001028
ROD: EV_AirbaVW10BPAVN750.rod
VCID: 387FF62E833B3F46F3-806C
Crash sensor for side airbag: driver side:
Serial number: 3495ZRB40693FGI6E89U
Crash sensor for side airbag: front passenger side:
Serial number: 3505ZRB40573FGI67P5P
Address 17: Instruments (J285) Labels:| 5K0-920-xxx-17.clb-SRI1
Part No SW: 7E0 920 970 L HW: 7E0 920 970 L
Component: KOMBI H05 1008
Serial number: 00000000000000
Coding: 710D010300
ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A05730
ROD: EV_Kombi_UDS_VDD_RM09_005_VW31.rod
VCID: 3365C1029A5DDC1EC6-8066
Address 18: Aux. Heat (J364) Labels:| 7E0-963-27X-18.clb
Part No SW: 7E0 963 273 HW: 7E0 963 273
Component: STH-T5GP2 002 0007
Coding: 4101
Shop #: WSC 02759 790 50316
ASAM Dataset: EV_AuxilParkiHeateWOST5G2 001010
ROD: EV_AuxilParkiHeateWOST5G2.rod
VCID: 6ADB1C668D175DD6B5-803E
Address 19: CAN Gateway (J533) Labels:. 7E0-909-901.clb
Part No SW: 7E0 909 901 HW: 7E0 937 090
Component: GW-K-CAN TP20 H80 0736
Revision: B9080001
Coding: 042305
1 Fault Found:
01300 - Control Module for Navigation with CD-Rom (J401)
004 - No Signal/Communication
Freeze Frame:
Fault Status: 01100100
Fault Priority: 2
Fault Frequency: 1
Reset counter: 67
Mileage: 27773 km
Time Indication: 0
Date: 2020.11.23
Time: 09:06:01
Address 25: Immobilizer (J334) Labels:| 5K0-920-xxx-25.clb
Part No SW: 5K0 953 234 HW: 5K0 953 234
Component: IMMO H05 1008
Serial number:
Coding: 000000
ASAM Dataset: EV_Immo_UDS_VDD_RM09 A03710
ROD: EV_Immo_UDS_VDD_RM09_VW31.rod
Address 37: Navigation
Cannot be reached
Address 56: Radio
Cannot be reached
Address 61: Battery Regul. (J840) Labels:. 1K0-907-534.clb
Part No SW: 7E0 907 534 HW: 7E0 937 090
Component: Batt.regelung H80 0736
Coding: 030B1A73
Shop #: WSC 02739 790 00000
Subsystem 1 - Part No SW: 7E0 915 181 G HW: 7E0 915 181 G
Component: J367-BDM H08 0223
Serial number: 52232F34531261520254
Address 69: Trailer (J345) Labels:. 1K0-907-383-V2.clb
Part No SW: 1K0 907 383 F HW: 1K0 907 383 F
Component: Anhaenger H12 0100
Revision: 3A001001 Serial number: 00000495347083
Coding: 0100000100000000
Shop #: WSC 12345 123 12345
VCID: 306FCE0E634BE706BB-8064
End-------------------------(Elapsed Time: 03:05)--------------------------
