Hello,if you type in New Genuine VW Transporter interior light upgrade they are there for £15.99 from a seller called partsdepot_uk,sorry I've just seen your message or i couldve saved you a tenner!
Where do they go? I don't think I've got enough lights to fit them in?!![]()
Each light has four lamps in it as per the above, most of the LEDs are too large to fit in them so you need the smaller ones and will need to split the fitting to get them in as they generally do go in from the rear like the standard lamps do, it’s not that bad just remove the complete fitting to fiddle with itThey look more of a strip than a single bulb has anyone changed these for led?. Gonna habve a play in a bit.
