2 x VW T5 Campervan Elevating Roof Gutter Channels, Window Rain Gutter Channel | eBay
Bought these come as a pair
Looks like exactly the same product I bought and posted the original link for but, if after 2 (which I’d recommend), somewhat cheaper on your link.2 x VW T5 Campervan Elevating Roof Gutter Channels, Window Rain Gutter Channel | eBay
sorry to hear that pal, typicalI think I paid that for 1![]()
Another good reason to be on the forum, will order today, again only the driver’s side but always get a nice run of water! Thanks for continued adviceThanks for the link, just what I have been looking for. Have an SCA roof with a multi rail on the passenger side but keep getting dripped on from the drivers side.
I have reimo rails rails on both sides..My (pop top) roof collects a bit of rain water above the drivers door which then runs away down the middle of the drivers window. No real problem until you open the door to get in and out - you get wet ! No problem on the passenger side because the Reimo multi rail channels the water away and down the windscreen.
It might be an expensive fix, but can you get reimo multi rails and end caps for the drivers side?
Failing that, has anyone any bright ideas how I can fabricate something to channel the water away down the windscreen??
I have used Silkaflex expensive but works - also used VERY carefully some Superglue!!! It worked for a good 6 months!I’ve got one of these rain gutters above my driver’s door (Reimo rail above passenger door) but it’s come unstuck at one end. Does anyone know the best type of adhesive to use to stick it back down onto the vehicle?
Sikaflex is the best - expensive, but the bestI have used Silkaflex expensive but works - also used VERY carefully some Superglue!!! It worked for a good 6 months!
Meant to say: try sourcing from your local caravan servicing outfit as they use loads...avoid buying something that’s been sat on a shelf for yearsSikaflex is the best - expensive, but the best
