I have replaced the Right Rear wheel sensor twice now. And the left. So I obviously have a problem and these are just symptoms. The latest popped up on way to Scotland. So had to drive back with no ACC. I have come to rely on this and is my favourite thing. I have just plugged in the VCDS and this is what I have. Any recommendations, observations are welcome. Van has just driven 700m (ish) to Scotland and back to that Surrey.
Code:
Saturday,27,April,2024,11:01:26:10375
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64
VCDS Version: 23.11.0.0 (x64) HEX-V2 CB: 0.4643.4
Data version: 20240205 DS351.0
www.Ross-Tech.com
Chassis Type: 7E0
Scan: 01 02 03 04 08 09 10 13 15 17 19 22 25 55 5F 61
01-Engine -- Status: Malfunction 0010
02-Auto Trans -- Status: OK 0000
03-ABS Brakes -- Status: Malfunction 0010
04-Steering Angle -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: OK 0000
10-Park/Steer Assist -- Status: OK 0000
13-Auto Dist. Reg -- Status: OK 0000
15-Airbags -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
22-AWD -- Status: Malfunction 0010
25-Immobilizer -- Status: OK 0000
55-Headlight Range -- Status: Malfunction 0010
5F-Information Electr. -- Status: Malfunction 0010
61-Battery Regul. -- Status: OK 0000
Address 01: Engine
Cannot be reached
Address 02: Auto Trans
Cannot be reached
Address 03: ABS Brakes
Cannot be reached
Address 08: Auto HVAC
Cannot be reached
Address 09: Cent. Elect. (J519) Labels:. 7E0-937-BCM-V1.clb
Part No SW: 7E0 937 090 B HW: 7E0 937 090
Component: BCM PQ25 Max4 H81 0744
Revision: B9081001 Serial number: 0982 317160166
Coding: A1FC793A0A61341193284F606CEB8FF4C084738960CD79603204003F0860
Shop #: WSC 02737 534 735210
VCID: 2A0D118D1CFDA12A517-807E
Subsystem 1 - Part No: 5K7 955 559 C Labels: 5K7-955-559.CLB
Component: RLS 191016 04 42 0106
Coding: 0228EE
Subsystem 2 - Part No SW: 7E0 959 801 Q HW: 7E0 959 801 Q Labels: 7E0-959-80X-V2.CLB
Component: J386__TSG_FT 003 0653
Serial number: KU0KU003111663080582
Coding: 1400B1
Subsystem 3 - Part No SW: 7E0 959 802 Q HW: 7E0 959 802 Q Labels: 7E0-959-80X-V2.CLB
Component: J387__TSG_BT 003 0653
Serial number: KU0KU003111663087147
Coding: 0400A1
Subsystem 4 - Part No: 7E1 951 172
Component: DWA-Sensor 00 001 0104
Coding: 000000
Subsystem 5 - Part No: 1K0 951 605 C
Component: LIN BACKUP HO H05 1501
Coding: 000000
Subsystem 6 - Part No: 7E1 951 172
Coding: 000000
No fault code found.
Address 10: Park/Steer Assist
Cannot be reached
Address 13: Auto Dist. Reg
Cannot be reached
Address 15: Airbags
Cannot be reached
Address 17: Instruments
Cannot be reached
Address 19: CAN Gateway (J533) Labels:. 7E0-909-901.clb
Part No SW: 7E0 909 901 HW: 7E0 937 090
Component: GW-K-CAN TP20 H81 0744
Revision: B9081001
Coding: 042307
VCID: 6889AB85C271533A873-803C
Address 22: AWD
Cannot be reached
Address 25: Immobilizer
Cannot be reached
Address 55: Headlight Range
Cannot be reached
Address 5F: Information Electr.
Cannot be reached
Address 61: Battery Regul. (J840) Labels:. 1K0-907-534.clb
Part No SW: 7E0 907 534 HW: 7E0 937 090
Component: Batt.regelung H81 0744
Coding: 030B1A73
Shop #: WSC 02739 790 00000
Subsystem 1 - Part No SW: 7E0 915 181 K HW: 7E0 915 181 K
Component: J367-BDMConti H03 1050
Serial number: 75410903001611040844
End----(Elapsed Time: 01:27, VBatt start/end: 12.4V/12.4V. VIgn 0.0V)------
Code:
Chassis Type: 7H-VN75 (7E0)
Scan: 01 02 03 04 08 09 10 13 15 17 19 22 25 55 5F 61 0B
VIN: WV1ZZZ7HZHH086221 Mileage: 76980km-47833miles
Address 01: Engine (2D2D2-CXEB) Labels:. 04L-907-309-V2.clb
Part No SW: 04L 906 056 KN HW: 04L 907 445 A
Component: R4 2.0l BTD H03 3776
Revision: 23101001
Coding: 00254014436701080000
Shop #: WSC 02737 790 50316
ASAM Dataset: EV_ECM20BTD03004L906056KN 004004
ROD: EV_ECM20BTD03004L906056KN_004.rod
VCID: 03539C29DB979062321-8056
VINID: 9E606AAAA1D8A9860020608204504E739F
2 Faults Found:
15560 - EGR Sensor 1
P046C 00 [01101100] - Implausible Signal
Intermittent - Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 75606 km
Date: 2080.01.17
Time: 12:48:01
Engine RPM: 0.00 /min
Normed load value: 0.0 %
Vehicle speed: 0 km/h
Coolant temperature: 29 ∞C
Intake air temperature: 12 ∞C
Ambient air pressure: 990 mbar
Voltage terminal 30: 12.445 V
Unlearning counter according OBD: 40
Mass airflow sensor 1 bank 1 airflow: raw value: 0.0 mg/stroke
Exhaust recirc.valve 1 bank 1: posit.feedback - Specified value: -3.59 %
Exhaust recirc.valve 1 bank 1: posit.feedback - Actual value: -3.54 %
Exhaust recirc.valve 1 bank 1: posit.feedback - Offset closed: 0.00 %
Exhaust recirc.valve 1 bank 1: posit.feedback - Raw voltage: 2.501 V
EGR vacuum regulator solenoid valve 1 bank 1: res. Cooling mode stop: 2.318 V
EGR vacuum regulator solenoid valve 1 bank 1: res. Bypass operation stop: 2.800 V
25126 - Databus
U1123 00 [00101111] - Received Error Message
Freeze Frame:
Fault Priority: 6
Fault Frequency: 9
Mileage: 76119 km
Date: 2084.01.18
Time: 02:17:37
Engine RPM: 933.50 /min
Normed load value: 60.8 %
Vehicle speed: 1 km/h
Coolant temperature: 83 ∞C
Intake air temperature: 22 ∞C
Ambient air pressure: 1010 mbar
Voltage terminal 30: 11.875 V
Acceleration: -0.139 m/s≤
Cruise Control System (CCS): status: passive
Drivetrain coordinator: ACC fault status-ACC is active despite EPB deceleration: No
Drivetrain coordinator: ACC fault status-ACC active: although TSK passive: No
Drivetrain coordinator: ACC fault status-Start off or stop request at stopping speed not set: No
Drivetrain coordinator: ACC fault status-Start off and stop request sent simultaneously: No
Drivetrain coordinator: ACC fault status-ACC active: although limiter active: No
Drivetrain coordinator: ACC fault status-ACC reactivates itself after locking: No
Drivetrain coordinator: ACC fault status-ACC sends undefined signals: No
Drivetrain coordinator: ACC fault status-ACC active although main switch off: No
Drivetrain coordinator: ACC fault status-ACC is active despite driver braking: No
Drivetrain coordinator: ACC fault status-ACC is active despite ESP/ASR passive sampling: No
Drivetrain coordinator: brake function status-ABS intervention: No
Drivetrain coordinator: brake function status-ESP intervention: No
Drivetrain coordinator: brake function status-EDL intervention: No
Drivetrain coordinator: brake function status-ASR intervention: No
Drivetrain coordinator: brake function status-MSR intervention: No
Drivetrain coordinator: brake function status-Driver braking: No
Drivetrain coordinator: brake function status-HDC active: No
Drivetrain coordinator: brake function status-ESP invokes TSK braking: No
Drivetrain coordinator: brake function status-EPB active: No
Drivetrain coordinator: brake function status-ASP intervention: No
Drivetrain coordinator: brake function status-ADS intervention: No
Drivetrain coordinator: brake function status-Stopping distance reduction2 warning jolt: No
Drivetrain coordinator: brake function status-ESP sampled passive (ESP off): No
Drivetrain coordinator: brake function status-ASR sampled passive (ASR off): No
Drivetrain coordinator: brake function status-ESP recognizes vehicle at rest: No
Drivetrain coordinator: brake function status-ACC stopping distance control active: No
Drivetrain coordinator: brake fault status-Deceleration sensor not available: No
Drivetrain coordinator: brake fault status-Deceleration sensor malfunction: No
Drivetrain coordinator: brake fault status-ESP system error: No
Drivetrain coordinator: brake fault status-ESP system malfunction due to inaccurate engine torque: No
Drivetrain coordinator: brake fault status-ESP indicates TSK message consistency error: No
Drivetrain coordinator: brake fault status-TSK/ESP handshake error: No
Drivetrain coordinator: brake fault status-ESP automatic engagement malfunction: No
Drivetrain coordinator: brake fault status-Brake light implausible: No
Readiness: N/A
Address 02: Auto Trans (J743) Labels:. 0BH-927-711.clb
Part No SW: 0BT 300 012 C HW: 0BH 927 711 G
Component: DSG DQ500-7A H11 5302
Revision: 00H11V01 CVN: E785A3F3
Coding: 0014
Shop #: WSC 00000 000 00000
ASAM Dataset: EV_TCMDQ500021 001001
ROD: EV_TCMDQ500021.rod
VCID: 2F3B0099279FC402869-807A
Address 03: ABS Brakes (J104) Labels: 7E0-907-37x-MK100ESC.clb
Part No SW: 7E0 907 379 Q HW: 7E0 907 379 N
Component: ESC H06 0133
Revision: 00000000 Serial number: 42906000001544
Coding: 307EC098656A84840C770378A683219379F700
Shop #: WSC 02739 790 50316
ASAM Dataset: EV_Brake1ESCCONTIVN75XGP2 011001
ROD: EV_Brake1ESCCONTIVN75XGP2_011.rod
VCID: 40D953258A014B7A6F3-8014
6 Faults Found:
0071 - Rear Left Wheel Speed Sensor
C101C 4A [00001000] - Incorrect Component(s) Installed
Freeze Frame:
Fault Priority: 1
Fault Frequency: 2
Reset counter: 102
Mileage: 76345 km
0073 - Rear Left Wheel Speed Sensor
C101C 29 [00001000] - Signal Implausible
Freeze Frame:
Fault Priority: 2
Fault Frequency: 3
Reset counter: 103
Mileage: 76143 km
Date: 2024.04.23
Time: 02:32:06
0075 - Rear Left Wheel Speed Sensor
C101C 07 [00001000] - Mechanical Failure
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 102
Mileage: 76347 km
Date: 2024.04.25
Time: 22:02:43
0079 - Rear Left Wheel Speed Sensor
Freeze Frame:
Fault Priority: 2
Fault Frequency: 3
Reset counter: 102
Mileage: 76119 km
Date: 2024.04.23
Time: 02:17:37
0298 - Steering angle sensor
B1168 07 [00001000] - Mechanical Failure
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 100
Mileage: 76121 km
Date: 2024.04.23
Time: 02:20:17
4197 - Rear Left Wheel Speed Sensor
C101C 14 [10001001] - Open or Short to Ground
MIL ON - Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Priority: 2
Fault Frequency: 14
Reset counter: 64
Mileage: 76194 km
Date: 2024.04.23
Time: 03:00:57
Address 04: Steering Angle (G085) Labels:* 6R0-959-654.clb
Part No SW: 6R0 959 654 HW: 6R0 959 654
Component: LENKW.SENSOR H07 0070
Serial number: 01111613470554
Coding: 01
ASAM Dataset: EV_LWSKLOVW25X 005001
ROD: EV_LWSKLOVW25X.rod
VCID: 7EA5EDDDB075FD8A5DF-802A
Address 08: Auto HVAC (J301) Labels:| 7E5-907-047.clb
Part No SW: 7E0 907 047 AC HW: 7E0 907 047 AC
Component: Climatic-T5 H22 0708
Revision: 00001002
Coding: 0000000003
ASAM Dataset: EV_ClimaticT5 A01003
ROD: EV_ClimaT5Basis.rod
VCID: 6B83D489D3077822EA1-803E
Coding: 0228EE
Coding: 1400B1
Coding: 0400A1
Coding: 000000
Coding: 000000
Coding: 000000
Subsystem 7 - Part No SW: 7E0 959 442 A HW: 7E0 959 442 A Labels: 3C8-959-537.CLB
Component: E221__MFL-DC1 H02 0103
Serial number: 29160002250750106441
Coding: B4FFFF
Address 10: Park/Steer Assist (J446) Labels:| 7E0-919-475.clb
Part No SW: 7E0 919 475 AA HW: 7N0 919 475
Component: PARKHILFE 8K H06 0212
Revision: -------- Serial number: 28261627801108
Coding: 30810C
ASAM Dataset: EV_VW75XParkAssis8K 001012
ROD: EV_VW75XParkAssis8K_001_VN75.rod
VCID: 71BFC6E1F12B92F2D0D-8024
Address 13: Auto Dist. Reg (J428) Labels:| 7N0-907-572.clb
Part No SW: 7N0 907 572 C HW: 7E0 907 572
Component: ACC Bosch PQx H03 0211
Serial number: 31101604404077 Dataset Number: 7E0114v____ 0009
Coding: 00005000FE0779
Shop #: WSC 01383 790 50316
ASAM Dataset: EV_ACCBEGVW361 001006
ROD: EV_ACCBEGVW361.rod
VCID: 363535FDD8C5F5CAC5F-8062
10 Faults Found:
1067 - Brake Temperature
C10DF 00 [00001001] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 13
Reset counter: 64
Mileage: 76119 km
Date: 2024.04.23
Time: 02:17:37
Control Module temperature: 18 ∞C
Voltage terminal 15: 11.9 V
Vehicle speed: -0.43 m/s
Acceleration: -0.01 m/s≤
1058 - Databus
U1123 00 [00001001] - Received Error Message
[FAULT_CIS_ECD_NOTAVAILABLE]
Freeze Frame:
Fault Priority: 6
Fault Frequency: 13
Reset counter: 64
Mileage: 76119 km
Date: 2024.04.23
Time: 02:17:37
Vehicle speed: -0.45 m/s
Acceleration: -0.18 m/s≤
1059 - Databus
[FAULT_CIS_ESP_FAIL]
Freeze Frame:
Fault Priority: 6
Fault Frequency: 14
Reset counter: 64
Mileage: 76119 km
Date: 2024.04.23
Time: 02:17:37
Voltage terminal 15: 11.8 V
Acceleration: -0.20 m/s≤
1037 - Databus
U1123 00 [00001000] - Received Error Message
[FAULT_CIS_QDCACC_FAIL]
Freeze Frame:
Fault Priority: 6
Fault Frequency: 11
Reset counter: 104
Mileage: 76148 km
Date: 2024.04.23
Time: 02:35:03
Control Module temperature: 22 ∞C
Voltage terminal 15: 13.2 V
Vehicle speed: 32.77 m/s
Acceleration: 0.09 m/s≤
1544 - Function restriction
C10C2 00 [00001000] - -
[FAULT_REFERENCE_VELOCITY_NOT_AVAILABLE]
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 101
Mileage: 76347 km
Date: 2024.04.25
Time: 22:02:36
Control Module temperature: 15 ∞C
Voltage terminal 15: 14.7 V
Vehicle speed: 14.23 m/s
Acceleration: 0.25 m/s≤
1043 - Automatic Distance Control
B10E7 F0 [00001001] - Disconnected
[FAULT_CIS_TSK_IRREV_FAIL]
Freeze Frame:
Fault Priority: 6
Fault Frequency: 8
Reset counter: 64
Mileage: 76119 km
Date: 2024.04.23
Time: 02:17:37
Vehicle speed: -0.44 m/s
Acceleration: -0.10 m/s≤
1118 - Databus
[FAULT_CIS_WHEEL_PULSE_FAIL]
Freeze Frame:
Fault Priority: 6
Fault Frequency: 8
Reset counter: 64
Mileage: 76143 km
Date: 2024.04.23
Time: 02:32:06
Control Module temperature: 23 ∞C
Voltage terminal 15: 13.1 V
Vehicle speed: 32.69 m/s
Acceleration: 0.01 m/s≤
1119 - Databus
[FAULT_CIS_WHEEL_PULSE_INVALID]
Freeze Frame:
Fault Priority: 6
Fault Frequency: 6
Reset counter: 102
Mileage: 76119 km
Date: 2024.04.23
Time: 02:17:37
Acceleration: -0.16 m/s≤
1081 - Databus
[FAULT_CIS_WHEEL_RPM_FAIL]
Freeze Frame:
Fault Priority: 6
Fault Frequency: 8
Reset counter: 64
Mileage: 76143 km
Date: 2024.04.23
Time: 02:32:06
Vehicle speed: 32.68 m/s
Acceleration: -0.04 m/s≤
1082 - Databus
[FAULT_CIS_WHEEL_RPM_INVALID]
Freeze Frame:
Fault Priority: 6
Fault Frequency: 6
Reset counter: 102
Mileage: 76119 km
Date: 2024.04.23
Time: 02:17:37
Acceleration: -0.12 m/s≤
Address 15: Airbags (J234) Labels:| 5K0-959-655.clb
Part No SW: 7E0 959 655 H HW: 7E0 959 655 H
Component: VW10Airbag01S H08 0018
Revision: -------- Serial number: 003V4001L2N% Dataset Number: 7E0003V____ 0909
Coding: 000000000000000000000000000000003153
Shop #: WSC 02734 790 50316
ASAM Dataset: EV_AirbaVW10BPAVW12X 001028
ROD: EV_AirbaVW10BPAVN750.rod
VCID: 3B2324C9E3E728A23A1-806E
Crash sensor for side airbag: driver side:
Serial number: 3495ZRB4012578IUA0V
Front Passenger's Side Airbag Crash Sensor:
Serial number: 3505ZRB401I579TEF8G/
Address 17: Instruments (J285) Labels:| 5K0-920-xxx-17.clb-SRI1
Part No SW: 7E0 920 970 S HW: 7E0 920 970 S
Component: KOMBI H03 1104
Serial number: 00000000000000
Coding: 440F010300
ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A05733
ROD: EV_Kombi_UDS_VDD_RM09_005_VW25.rod
VCID: 3A2D21CDECDD11AA217-806E
Revision: B9081001
Coding: 042307
Address 22: AWD (J492) Labels:* 0CQ-907-554.clb
Part No SW: 0AY 907 554 L HW: 0CQ 525 130 A
Component: Haldex4Motion H53 7620
Serial number: HA1-00023.09.16 Dataset Number: v1260x015G0 0000
Coding: 0505
ASAM Dataset: EV_AllWheelContrHA1VW37X 002015
ROD: EV_AllWheelContrHA1VW37X.rod
VCID: 54F16F756E79C7DADBB-8000
2 Faults Found:
16670 - All-Wheel Drive
C1113 07 [00001000] - Mechanical Failure
Freeze Frame:
Fault Priority: 1
Fault Frequency: 1
Reset counter: 102
Mileage: 76347 km
Date: 2024.04.25
Time: 22:02:36
16656 - Databus
[Bremsensteuerger‰t - no speed signal]
Freeze Frame:
Fault Priority: 6
Fault Frequency: 17
Reset counter: 64
Mileage: 76143 km
Date: 2024.04.23
Time: 02:32:05
Address 25: Immobilizer (J334) Labels:| 5K0-920-xxx-25.clb
Part No SW: 5K0 953 234 HW: 5K0 953 234
Component: IMMO H03 1104
Serial number:
Coding: 000000
ASAM Dataset: EV_Immo_UDS_VDD_RM09 A03710
ROD: EV_Immo_UDS_VDD_RM09_VW21.rod
VCID: 6A8DD18DDCFD612A917-803E
Address 55: Headlight Range (J431) Labels:. 6R0-907-357.clb
Part No SW: 6R0 907 357 C HW: 6R0 907 357 B
Component: AFS-ECU 005 0050
Revision: -------- Serial number: -------------- Dataset Number: V03600097E0 0001
Coding: 0FCE020001000000
Shop #: WSC 02757 790 50316
ASAM Dataset: EV_HeadlRegulVWLWRCC 002006
ROD: EV_HeadlRegulVWLWRCC.rod
1 Fault Found:
13705985 - Databus
U1123 00 [10001001] - Received Error Message
[Fehlerwert im Signal BR3_Rad_kmh_HL]
Freeze Frame:
Fault Priority: 6
Fault Frequency: 18
Reset counter: 64
Mileage: 76119 km
Date: 2024.04.23
Time: 02:18:21
Address 5F: Information Electr. (J794) Labels:| 5G0-035-MIB-STD2.clb
Part No SW: 5C0 035 680 E HW: 5C0 035 680 E
Component: MU-S-ND-ER H31 0359
Serial number: VWZAZ2S5348181 Dataset Number: V03935249AT 0001
Coding: 065700013C00000011111101008808001F0100D6002001004F
ASAM Dataset: EV_MUStd4CTSAT 001022
ROD: EV_MUStd4CTSAT_VN75.rod
VCID: 2313FCA97B577062121-8076
Data carrier:
Subsystem 1 - Part No SW: 3G0 919 866 AQ HW: -----------
Component: ECE1 2017 --- 0730
Serial number: --------------------
Coding: 030B1A73
End----------(Elapsed Time: 02:02, VBatt start/end: 12.0V/12.0V)-----------
