Get a 2 pin adapter, sites are slowly changing over to the 3 pin standard but the majority over there still haven’t.Hi guys
Going away in June for a month Switzerland and Italy, do i need to purchase any hook up adapters or will the end I use in the up work, any links to what I need if I need it would be great
Cheers Steve
Interesting about Switzerland, trust them to be different. Yes I find generally the further east you go, the more anything goes as regards to electrical safety. In Hungary I was at a site where so many splitters and adapters came off a single socket it looked like a mass of spaghettiAs above, have two pin connector for most of European sites (and Aires) that have not fitted standard blue 16A sockets.
However you may find a socket type that is unique to Switzerland but I have found where these exist the site will lend you an adaptor.
In France you may find EHUs are remote from your pitch so long cables are a good idea. I have two 25m cables, and a three way adaptor (16A plug & 3 16A outlets) so that I can 'share' power connections. That seems to be frowned on here in the UK but common place in France.
Rod
there was only a possibility of connecting into a screw terminal block for power!!
Yes I forgot about that, I have a little polarity checker that I keep permanently plugged into one socket and a polarity changing pigtail to put inbetween when necessary.Sounds like Morocco! There are some great locations there but many lapse into disrepair and nothing gets fixed.
Agree with the above, long leads and a 2 pin adapter. We have also been on a couple of sites that insist you do a Live-Neutral polarity check with 2 pin European sockets. These have been where the connections are locked away and they come and connect you. A plug in polarity checker can be useful for this. This can be just one you put into your vans 13A socket assuming you have one: https://www.amazon.co.uk/Silverline-783103-Socket-Tester-Diameter/dp/B000LFXIIK
great advert for a big solar panel
I’m currently in Portugal having driven down through Spain, used the 2pin adapter on most sites.I have just travelled from France to Belgium to Holland to Denmark and have used only the standard UK adapter but now in Sweden and have had to use the two pin adapter.
One thing I’ve noticed since getting the Bluetooth Victron solar controller, is that my solar panel is shutting down when it’s getting hot (currently in Portugal & it’s been Mid-30s during the afternoons) the panel voltage is dropping from typically 20v to 10-11V. As soon as it cools down or we get into semi shade, it comes back up & starts changing.Having said that, all of this stuff is a great advert for a big solar panel and I don't take mains hookup kit with me any more
