Talk to @BognorMotors or @The Van Cave, they are the gurus on this subject!
Sorry to confuse; I'm after wider/larger wheels than the skinny stock 205/65 16s. Suspension is not a concern to me and looks will be a natural advantage of course.I must confess - I’m very confused! @rileyrussell.89 do you want to change/improve how the van looks or do you want to change/improve how the van rides/handles? Do you know if your van is a T32 or other variant?
If a “problem” could be articulated then a clearer view on potential solutions could be put forward. That could even be: “I’d like my van to be lowered, with wheels that fill the arch more yet still provide comfortable handling!”
Just trying to help steer a route through my confusion!
Cool, that helps! I think the confusion arose from your original post that that 16” wheels contributed to the body roll.Sorry to confuse; I'm after wider/larger wheels than the skinny stock 205/65 16s. Suspension is not a concern to me and looks will be a natural advantage of course.
The offsets I gave you were pretty conservative and would also work with 8.5 wide wheels. Run the 255/45 18 tyre to keep the required load rating and you'll have no problems.Thankyou for the feedback. Am I right in thinking a wider rim (say 8.5) would benefit from a wider offset (say 35) to get that inside edge away from anywhere itll rub?
I think I may have used the term roll in the wrong way... I understand body roll is suspension, I meant more the loose grip/sidewall flex from the stockers which can feel like roll.The offsets I gave you were pretty conservative and would also work with 8.5 wide wheels. Run the 255/45 18 tyre to keep the required load rating and you'll have no problems.
Body roll won't be improved with bigger wheels/wider tyres. In a simple world where all other things remain the same, a wider tyre will give you more grip, but that doesn't reduce body roll. To reduce body roll you will need to upgrade your shocks or the anti roll bars, or better still both. Both can be done without lowering the vehicle if you still want to maintain the standard ride height.
YepI think I may have used the term roll in the wrong way... I understand body roll is suspension, I meant more the loose grip/sidewall flex from the stockers which can feel like roll.
In australia 255/55/18 are the most common for the load rating, would I be safe with that size in a 38 offset on 8.5 rims?
