Got the dreaded flashing coil light again. DPF ?
A&A
Got the dreaded flashing coil light again a couple of weeks ago with the following fault codes:
P20EE00
P200600
P200400
P012100
I have since had new vacuum activator fitted (1K0906627H) and loose pipe firmed up.
Light is still coming on.
Two years ago and (and about 40,000 miles) I had a new manifold fitted (04L129709E)
The van does a lot of 8 mile trips and less frequent long trips.
Any suggestions what to do next. Thanks. Andy
P20EE00
P200600
P200400
P012100
Which of the faults triggered the flashing coil light - that information is part of the fault code details (aka freeze frame data)
What was the reasoning for the replacement?
What were the fault codes now?
Why? Any fault codes then?
Please provide more details: which engine (code from sticker under dash), mileage, perhaps a proper diagnostics scan?
modelof van: T32 Kombi Highline SWB EU6 150PS 2.0 TDI BMT 7sp DSG
And it is a 2018 T6
Reactions: mmi
Soot level via carista app .53oz (15g) after carista regen .31oz (8.8g)
That's normal.
But was also the actuator replaced or is it still the original? (04L 129 061 A)
details from carista:
Basic OBD2:
P2006 (Pending) - Intake Manifold Runner Control Stuck Closed Bank 1
Engine:
16399 - Intake Manifold Runner Control Bank 1: Stuck Closed
Freeze frame :
Priority: 2
Malfunction frequency counter: 1
Unlearning counter: 255
Odometer reading: 90958.2 miles
Engine rpm: 1200 RPM
Normed load value: 55.7 %
Vehicle speed: 3.1 mph
Coolant temperature: 194 °F
Intake air temperature: 68 °F
Ambient air pressure: 14.65 PSI
Voltage terminal 30: 13.328 V
25126 - Invalid Data Received From Vehicle Dynamics Control Module
Freeze frame :
Priority: 6
Malfunction frequency counter: 13
Odometer reading: 90745.6 miles
Engine rpm: 1809.5 RPM
Normed load value: 47.8 %
Vehicle speed: 8.1 mph
Coolant temperature: 140 °F
Intake air temperature: 61 °F
Voltage terminal 30: 13.32 V
