Thanks for that @WillWillWill - reassuring to know that you had the same fault codes on your 4motion when it was just a failed sensor. There isn't loads of info generally about 4motions I find. I was wondering if there was something more serious going on.
I run a dashcam with park mode off my vehicle battery and it had been standing for a day or so when I took the voltage, so it'll have drained the battery before hitting the low voltage cut off - hence my lower voltage. I didn't go through the other diagnostic steps, it'll be a bit more involved as I'll need to take the passenger seats and swivel base out to locate and access the connectors.
Swapping the sensor is reasonably easy to do, as long as the current one comes out nicely, so I think I'll probably do that as my next step. If that fails, then I'll take the passenger seats and swivel base out and get into the diagnostic steps with the wiring loom.
