[Guide] Fitting a steering wheel
Kev_
I’ve been thinking about the flat bottom mod for a while so thought I’d write a how to for anyone else that is interested.
The reasons I like it are:
  1. Vanity (Flat bottom steering wheels are cool)
  2. DSG paddles
  3. Fuel Economy (we’ll get to that later)
  4. It’s easier to turn a flat bottom and it fits past my fat legs!
Warning: if you don’t disconnect your battery then your airbag could go off when you disconnect the plug. Even worse than that, when you release the first airbag spring clip your horn will get stuck on and your neighbours will think you’re a bellend!
Some things to know:
  • Not every VW flat bottom wheel will fit your van if you’re planning to reuse your original air bag. We’re looking for wheels with the 2 hooks that the airbag attaches to.
  • If you buy a wheel which includes an airbag (from a Polo for instance) you need to make sure that it has the same button layout or it won’t work
I currently have a highline MFSW without ACC. I bought a second hand VW Golf Mk7/ Passat B8 wheel which had covered 10,000 KM with ACC and when I received it, it is a brand new wheel. I paid £105 and the part number is: 5G0419091. Some people use Golf R and Golf GTI/GTD wheels but I wanted the OEM look, personal preference.
There are plenty of these wheels on ebay in excellent condition and don’t be put off by the ones without an airbag or without the buttons/surround because in this case we re-use them from your original wheel.
Tools
  • 10mm socket
  • Phone or inspection mirror
  • Flat head screwdriver
  • M10 spline
  • Chisel
  • Hammer
  • Trim tools
How to:
  2. Ignition off
  3. remove key
  4. 10mm socket> Disconnect the negative terminal of the battery20201228_131337.jpg
  5. Unlock the steering column
  6. Pull it towards you and up as far as you can
  8. Find hole on back of steering wheel with inspection mirror (I took this picture before I disconnect the battery)20201228_131429.jpg
  9. Push the clip down until it clears the hook and the front of the horn pops out20201228_131522.jpg
  10. Spin the wheel 90 degrees
  11. Repeat 8 &9
  12. The airbag has now been release and you need to unplug it. Pull the white clip towards you to release the plug and disconnect20201228_131549.jpg
  13. Disconnect the plug from the airbag to the MFSW buttons20201228_131623.jpg
  14. Remove airbag and store in safe place
  15. Remove the centre nut with the m10 spline20201228_131644.jpg20201228_131655.jpg
  16. Mark the centre of the wheel with the chisel and hammer20201228_131717.jpg
  18. Remove the plastic trim and buttons using the trim tools working from the bottom up. Take your time, this will be the longest bit of the process. The trim is held in by barbs so just keep working them (Note the barb next to the button sticks out in to the wheel so be gentle)20201228_142949.jpg20201228_143137.jpg
  20. The DSG paddles work without any coding. Plug the plugs for the paddles in to the sockets on the back on the buttons and you’re good to go.
  21. Push your trim and buttons on to the new wheel and you’re good to go.20201228_131914.jpg
  22. Back in the van, line the wheel up with the mark you made20201228_131941.jpg
  23. Tighten the wheel back up to 30nm
  24. Plug everything back in
  25. Push the airbag back in
  26. Remove the key
  27. Reconnect the battery
  28. Take it for a test drive
  29. Get yourself a beer, you deserve it!
Fuel Economy: My original Highline wheel weighs 600 Grams more than the flat bottom one, so the money that you save on fuel pays for the wheel! ;)
Highline wheel:
Flat bottom wheel:
I know that's sad but I noticed the difference in weight when I picked it up.
Kev
Cheers for this @Kev_ .
the steering with the part number5G0419091, is this the same airbag as the one currently on your van, as in not round like the golf airbags?
Cheers @Kev_ .
Scouring eBay now lol. Like you say there are a lot but what do the letters at the end of the part number stand for?
DJ appears at the end of the part number quite a lot.
There were 2 at the place I bought mine for €80 without the buttons. I'll have a look for the link mate
Yep! Looks the same as mine mate
All I need to do now is learn German to order the wheel on the link you sent over.
Google translate will be very handy. :thumbsup:
cheers @Kev_
There are two on the site. One that you sent and another one which is £40 more. Must be newer.
Ah that right, didn’t notice. So absorbed in the wheel.
Bought the MFSW W paddles without the buttons as got those.
@Pauly can you help with finding these connectors which are what connects the DSG paddles to the MFSW and subsequently the car?
Received the wheel today to find they are both missing. The wiring is there just the connectors missing.
Properly annoyed.
Anyone help me with an idea where I can get the white connectors in the Image above?
Cheers for any help you can offer :thumbsup:
