I didn't set out to write so many guides but I did take photos when changing 4 out of 5 doors on my van this weekend , so it would be rude not to post them up for others' benefit. I take photos so I know how to put it back together!
The sliding doors are attached to the van on three carriers; the top roller carrier, the middle/rear roller carrier and bottom roller carrier. Each carrier allows fine tuning of the shut gaps after you have fitted the door.
You will need to remove the door card first, but there's no loom to contend with as all connections to the sliding door are through the contact block on the front edge which connects when the door is closed.
With a mate supporting the door, particularly to stop it falling into the side of the van, remove the two spline bolts from the top carrier (yes, we did this in the sodding rain )
With your mate now really braced to take the weight of the rear of the door, remove the spline bolts in the middle of the door. Slide the middle roller carrier towards the rear of the van to remove it from the door.
Now finally remove the spline bolts attaching the door to the bottom roller carrier. At this point you really have to also take the weight of the front half of the door, as your mate won't be very impressed if you don't (he didn't have a hood ). I had removed one of the three bolts before started to make this step quicker.
The door is then free and you can walk it away from the van and get a cup of tea.
To refit the door, reverse the steps.
