Sold H&r 40mm Lowered Springs For T32
Keep your old ones, change them back before you take it in for a claim. Chances of a suspension fault are pretty rare.
If you look at the H&R specs for theses springs, you will see it's the same part number for all T6's and T5's, so i'd say yes.
There appears to be 4 options for the transporter
29270 - 1, 2, 3 and 4 depending on the van’s weight capacity.
Google Image Result for https://www.vanstyle.co.uk/van/images/prod_thumbs/VA5576_vw_t5_t6_h&r_-40mm_lowering_springs_600_j_g.jpg
I’m confused, which application is correct..
Searching google is sh1te as it’s now more geared to ads than info!
Come on guys, help!
T30 LWB 150 axles are 1600kg F & 1625kg R
T32. 1710kg . & 1720
The official H&R site has the following spec
29270
-1 greater than 1551 F & GT 1551 R
-2 GT 1551 F & up to 1550 R
-3 up to 1550 F & GT 1551 R
-4 less than 1550 F & R
Therefore the 29270 -1 ‘s are the only ones to fit. Is this correct? Should the -2’s be fitted to a T32?
Update. H&R produce either a hard or soft spring for the front and rear. The 4 kits they offer are a permutation of the ratings.
-2 is a hard front and a soft rear so I believe.
Nothing to do with axle weights?
What H&R kits do others have fitted?
