Hello all,
I've fitted H7 to my panel van that left the factory with H4's. Everything works as it should except the DRL's.
Coded BYTE 22, BIT 2 = 0 (low beam forced off while high beam on).
I've tested the bulb - it works.
I've powered the bulb when in the headlight - it works.
The only other thing I've read/can see is BYTE 18 - changing it o '69', but I'm a bit unsure after reading the warning:
