H7 Headlight Unit
michael thorpe
Hi
As anyone got a photo of the back of a H7 headlight unit or a diagram trying to work out the best way to change the Dlr bulbs with out having to take units out
I'm 90% sure it's that. If you give it a twist/wiggle you should see the lamp moving. That photo was taken when the headlight units were taken fresh from the box during the H4>H7 upgrade. I remember thinking at the time these will be a arse to change. I hope the photo helps even if it's wrong.
Hi Ed Just been out and looked its definitely that could see the bulb moving think it will be easy to do if i move the battery and air box thanks
Update at changing the bulbs lost a bit of blood but its do able found it easier with the battery out and the top of the air box off and a mirror to see what your doing looks a lot better now.
