Thanks to the previous posts by CRD and Pauly I was able to change both my bulbs. Thank you.
I used the GE 130% Megalight Ultra bulbs, as recommended and tested by autoexpress above other brands.
Using the previous post I've added a few extra notes BELOW to make it real easy for the novice (like myself) and some pictures that may help.
I can notice a bit of an improvement. I can't say it looks 130% brighter at all. All I know is that it saves me £2500+ in yearning after the proper VW LED headlights.
Cheers.
• For the driver's side I just removed the top half of the air box to get access, much easier.
• Remove the 2 air flow sensor plugs (they don't just pull off, there is a push catch on each that you need to release to allow them to be pulled off).
• Slacken the large jubilee clip. A pipe wrench is good for this as it is a large metal spring/clip that holds it together. Gently push the air pipe to the right, away from the box, whilst gripping the spring/clip open.
• Flip up the couple of catches (one in front and one behind) that attach the top half of the air box to the bottom half.
• With a bit of jiggling, the top half of the air box will come off. DON'T force it, it is tight but will come out. There are a series of hooks on the left hand side of the box that need unhooking from the bottom left half.
• You will then get good access to the bulb cover and lamp.
• Be careful never to touch the glass of the bulbs with your hands as this will shorten the lifespan of them.
For the passenger side headlight.. Use a 13mm socket and loosen (not undo) the battery retaining clip. Once loose push the battery backwards as far as it will go and this should give you just enough room to replace the bulb.
