Sunday,05,January,2020,20:16:54:44719
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 7 x64
VCDS Version: 19.6.2.0 (x64)
Data version: 20190930 DS308.0
www.Ross-Tech.com
Workshop Code: 377 35110 000155
VIN: WV1ZZZ7H License Plate: SHARAN PANEL
Address 08: Auto HVAC Labels: 5K0-907-044.lbl
Control Module Part Number: 5K0 907 044 FP HW: 5K0 907 044 FP
Component and/or Version: Clima-Sharan H18 0204
Software Coding: 0000000408
Work Shop Code: WSC 35110 377 00155
ASAM Dataset: EV_ClimatronicSharan A01005 (VN75)
ROD: EV_ClimaAutoSharaBasis.rod
VCID: 7EF9CAB4F959DABFD5-802A
Fault Codes have been Erased
8 Faults Found:
9474161 - Motor for Defroster Flap
(Pin Assignment is the same as T5)
B1090 71 [009] - Actuator stuck
Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 2
Fault Frequency: 1
Reset counter: 128
Mileage: 86403 km
Date: 2043.14.02
Time: 05:08:12
9474417 - Motor for Front Air Distribution Flap
(Pin assignment is different so could be changed)
B1091 71 [009] - Actuator stuck
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 128
Mileage: 86403 km
Date: 2043.14.02
Time: 05:08:12
9476629 - Position Sensor for Rear Air Distribution Flap Motor
(Don't have one so somehow need to code out)
B109A 15 [009] - Open or Short to Plus
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 128
Mileage: 86403 km
Date: 2043.14.02
Time: 05:08:12
9472277 - Temperature Sensor for Rear Vent
B1089 15 [009] - Open or Short to Plus
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 128
Mileage: 86403 km
Date: 2043.14.02
Time: 05:08:12
9496597 - Sunlight Photo Sensor
(has one pin that needs swapping, may be ok after)
B10E8 15 [009] - Open or Short to Plus
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 128
Mileage: 86403 km
Date: 2043.14.02
Time: 05:08:12
9496613 - Sunlight Photo Sensor
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 128
Mileage: 86403 km
Date: 2043.14.02
Time: 05:08:12
9479189 - Signal Line for Air Quality Sensor
(still to be installed, had same fault in T5 panel - no issue)
B10A4 15 [009] - Open or Short to Plus
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 128
Mileage: 86403 km
Date: 2043.14.02
Time: 05:08:12
9480753 - Control/Display Unit for Rear Climatronic
(Don't have one and have deselected in long coding but still showing)
B10AA 31 [009] - No Signal
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 128
Mileage: 86403 km
Date: 2043.14.02
Time: 05:08:12
