Firstly, have you tried it on every directional setting? The Windscreen setting ignores the temperature setting because it assumes you need to clear the windscreen of condensation, which confuses drivers and leads them to think they’ve got a defective heater..It’s a t28 66 reg,bought it private so my fault for not checking
Hoping it’s something easy
not yet mateDid you resolve it, I've got the same problem
think so mate its not the coldest ac I've had, convinced myself controls faultyDoes the AC need re-gassing?
Often the problems reported are relative to no air being delivered on settings 1-3 but only on 4.Heater blowing only hot or warm... A bit cooler after air con, but then goes back to warm again. Is anubody had this?
Thanks mateSo it sounds like one of the motors behind the dash, controlled by the dial, has stopped working.
Can’t really help you any more as this is not a common problem.
I guess an error code might have been generated which you could read with Carista or similar.
Pete
