Thanks mate, another day another job haha..If you take the stepper motor off you’ll find that the plastic quadrant is broken
Contact @Tony P hes your manDid you manage to get the plastic clip from Vw or is it part of the air distribution housing as mine is broken too, must be a common fault
Can you buy the plastic quadrant separately or is it part of the air distribution housing as mine is broken tooIf you take the stepper motor off you’ll find that the plastic quadrant is broken
It’s not available anywhere I’ve directed you Indy previous postCan you buy the plastic quadrant separately or is it part of the air distribution housing as mine is broken too
If you contact @Tony P he will tell you like I said,Shame as it seems to be a common fault ,
What did you do
Did you have to change the whole housing
Cheers NiknakIf you contact @Tony P he will tell you like I said,
@Leighjcj how did you get on in the end?Ok so got the new arm from @Tony P which is spot on, a lot more substantial and a perfect fit. This is where I need some help.....
The motor without the arm in just keeps spinning when hot is selected... when the arm is in place the motor will not move position regardless of where the selector is **![]()
ah I see. Ok mate that’s good to learn - I’m considering a heated seat upgrade in future so I’ll be replacing my panel. It’ll be interesting to see if that resolves the problem itselfHi @Ads_Essex, still not 100% but partially due to my laziness!!
The short version is I replaced the stepper motor which opens/closes the hot/cold flap, also replacing the plastic control arm with the one Tony P supplied.
It then needed plugging in to reset the HVAC controls as the new motor needed to be calibrated to factory settings. A local specialist helped me out here as it wasn't playing ball at first.
The hot/cold selection was then sorted but the cycling of vent positions continued. After a little more troubleshooting and signal testing of various wiring (again by the local VW specialist) We're 99% sure this is a fault in the heater control panel but I just haven't picked up a replacement yet.
Did you move flaps to hottest position manually before refitting and turning heater control to the hottest setting so the motor was in the correct position?@Leighjcj how did you get on in the end?
Mine (Highline) is cycling between vent outlets and largely remaining at the highest temperature.
Yep we did all thatDid you move flaps to hottest position manually before refitting and turning heater control to the hottest setting so the motor was in the correct position?
Nice one hope you get it sorted okYep we did all thatthen with quite a bit of messing on VAG Com but got hot and cold sorted. Just the cycling of vents to sort
Hi Leigh, all good thanks mate, hope you had a good Xmas?@Tony P hope all is well mate. Unfortunately I need another one of your plastic quadrants if you can help![]()
