Hi, the exhaust gets very hot, as you now know so shouldn’t be near the plastic which melts. It needs to be kept behind this and egress via the dedicated outlet or through the metal heatshield. Not sure what heater you have but the exhaust does not look like a Eberspacher, Webesto etc.View attachment 160284View attachment 160285
Hopefully the pictures show the problem easily enough. A metallic scrape as I was coming off my driveway eventually lead me to look under the van. The diesel heater exhaust has heated up so much that the heat has melted the undertray through which it extends. It's a new undertray after the old one broke going through water in March and it was probably the first prolonged use of the heater about a month ago that's caused this. A garage installed the undertray and I asked them to put the round hole in the tray where the hole in the old one was to accommodate the exhaust. Looks like that wasn't done well enough. You can see that the exhaust is/was touching the plastic and as it's melted the exhaust has continued moving down (or to right in the pictures) and when the exhaust has cooled the melted plastic has set in that corrugated pattern - I had to break the pipe away from the plastic that had melted onto the exhaust, this has at least corrected the angle of the pipe and the driveway scrape.
At the moment the exhaust seems to be sitting as per the pictures above but once the heating goes on again it will probably continue melting it's way to a point where it will naturally stop through lack of force, but how far I don't know - I've no ramps so can't easily take the trays off. I've no idea how or if the exhaust is secured somehow above the tray.
Any thoughts, comments?
The pipe need to be supported adequately else it can move an touch something creating problems. I would take panel off, reroute pipe and then repair the hole.
You could use a hull egress port like this which may fit in the hole you have to save extending the pipe pipe but I am not sure if yours will fit.
