As said above, the differential side gear is available as a spare part, and all that is needed is the gearbox split to fit it.
If VW had fitted a third CV joint to the transfer shaft, instead of plugging it straight onto the stub shaft or into the DSG diff splines, this whole offside driveshaft issue would never have happened on any of the T5 & T6's. They wear out because there is nothing to take up any misalignment and wobble in the transfer shaft, so the splines slightly move around and gradually wear out. Nearside virtually never fails.
Yes mate. Had a quote off another garage, negotiated a discount with VW and by the time I paid them for what they've done already and trailered the van to the other garage it would have cost more so I've given VW the go ahead. Gearbox is on back order for two weeks.
Gearbox has come in early, vans all back together, providing it passes an extended road test tomorrow I can have it back. Better start emptying my piggy banks
Near side? or offside? Apart from the stripped splines in the differential side gear, what else broke inside the DSG that warranted a complete new box?
