Hello from Russ & Jan @Nutexa Frictions Ltd
Nutexa Frictions
Trade Member | 07784987282
Trade Member
Just a quick hello from myself and my Wife Jan, between us we run Nutexa Performance Brakes, specialising in brake discs/pads & big brake kits for VW commercial vehicles and VAG cars.
we can also remanufacture old worn clutches, and make new uprated clutches for remapped vans and cars.
I've attached pictures of a small selection of vehicles we've supplied with brakes
Glad you guys are on here now! Nutexa for the win everyday on friction materials. It's the only company we ever use!
You're in great hands with Nutexa. We can supply and fit the whole range of Nutexa products if required.
Also give these guys a follow on Instagram
thanks mate
I'll soon be in the market for a complete set of discs & pads for my T6 t32 17"chassis (big brake) 4mot. What are my options? do you do a "vehicle set"?
Hi, you’ll need the 340mm upfront and 294mm at the back.
We do these in a carbon steel uprated disc in various pattern or a plain disc version, and our own low dust formulation pads
We’ve got a Xmas promotion on now which is 10% off with XMASBRAKE at checkout on our website.
We are closed now until the 3rd Jan, all orders will be sent out when we return
Russ
Russ
Thanks for that. This might seem a daft question, but I've just had a look at your website & I'm not sure about the quantities. On the brake pad section, is an STN177 an axle set (4 pads) or a wheel set, (2 pads), the photo only shows a single wheel set. Do I need to order 1 x STN177 or 2?
Hi the pads are axle sets, so a set of four
And the discs are in pairs
If the discount code doesn’t work anymore let me know and I’ll extend. I’m not sure if I set it to expire last night
Russ
Just been on your website to order a set of rear discs & pads. All the rear discs are showing as " sold out", when are you expecting more stock in? cheers.
We have this one for the forum.
The 5% discount code needed at checkout is T6FORUM
