@CaliChris If it was me, i'd just give up mate and get a pro to remove the bolt. The problem is, one slip with a hammer or punch and you are going to trash a wheel that might end up costing as much to refurb than just getting a pro to remove the bolt in the first place.
Any news? I’ve potentially got 12 of these to drill out shortly....
If it was me, the final attempt would be to hammer the 12 point socket on and then using a stick welder, weld the socket onto the locking wheel nut through the centre of the socket. This gets lots of heat into the bolt and also physically joins to socket to the bolt.Thanks, I have given up and yes I have slipped a couple of times and caught the wheel.
Will be taking it to a local garage today hopefully they will sort it. Just so frustrating! What should have been a simple job. Also the fact the Cali is only just a year old and the wheels can only have been off the once - when the dealership fitted sport line springs for me 6 months ago. Thanks to everyone for their input, much appreciated.
I've got those - they are good for getting the rotating collar off but completely the wrong size for the remaining part of the bolt.@CaliChris ....just looked on Halfords web page ....have a look at Laser Locking Wheel Nut Remover
I think you'll be pleasantly surprised when you come to remove those - the nuts and studs will come out as one piece. Are they going into an alloy head?
Didn't realise it was a 996 - they have bolts fitting the exhaust manifold so the bolt heads will probably have crumbled away. Can you retrofit studs and brass nuts from a proper air cooled 911?I like your optimism, unfortunatly 996’s are not know for ease of fixing removal from the engine - I’m expecting a fight. I have procured one of these in readiness for battle...
You might have been using an angle grinder to trim your toe nails for 35 years too but that doesn't mean it's a good idea. On topic though, for anyone thinking about lubricating wheel bolt threads, you've got to be careful when you change the co-efficient of friction on your fasteners as if you use the same torque setting you will have greatly increased the clamp load between the wheel and the hub (probably not a bad thing for wheels) but you're also getting closer to the limit of the elastic range of the bolt so don't go crazy tightening them up and stay within the elastic range of the bolt. I find applications that use wheel nuts rather than bolts work better with some anti seize on the threads and I reduce the torque by about 30% to keep within the same tensile range (well, slightly above as wheel nut torque figures are quite conservative); for bolts my preference is to run a die down the threads to clean them up as necessary and make sure there's no galling on the shoulders (not an issue for our rotating collared bolts).This is the reason I use Coppaslip or now Nickelslip on all my vehicle wheel nuts/bolts, the scenario where I'm unable to get a wheel off when I need to never arises , and before anyone claims that that is dangerous and I'll die in a blazing fireball when all my wheels fall off, in over 35 years of motoring, that's never happened, not had a single bolt or nut come loose on any vehicle I've ever owned, but I've never needed anything more than a hand tool to get them off.
I had no idea you could buy this jig, I was going to suggest you make the same using the new manifold as a pattern. Good luck, I’d be using cobalt drills.I like your optimism, unfortunatly 996’s are not know for ease of fixing removal from the engine - I’m expecting a fight. I have procured one of these in readiness for battle...
I managed to bypass all the blurb to the part where he confirmed reducing the torque by 30% and noted he was using a nut example too.
