That probably ties in with when I stopped using it as my daily commuter.That's a much more likely (and obvious!) interpretation - does that fit with how you use the van?
I’m going to remove the dpf again and complete a longer soak with the Wynns dpf cleaner.
My only question still is why the fault code reappears immediately after clearing whilst just the ignition is on. It surely needs pressure in the exhaust to read soot levels whilst the engine is running.
