Liam007
Hi guys,
I've recently had my electric hook-up and leisure battery installed However it has developed some errors now. When i turn the ignition on I get a warning about the ESC and start-stop. I plugged carista in have four warnings, I've tried both clearing and resetting but no joy so far. Here are the fault codes and the full ECU diagnostic report. Thanks for reading
Fault codes
25809
25126
00166 Access/Start Authorization Switch (E415)
00778 Steering Angle Sensor (G85)
ECU info obtained with Carista 4.1 beta-8 for Android:
VIN: WV1ZZZ7HZJH074848
Engine
Part #: 04L906056KA
Component: R4 2.0l TDI
Coding: 00114014432401090000 (hex)
Fault codes:
25809 Manufacturer-specific code
25126 Manufacturer-specific code
ABS
Part #: 7E0907379P
Component: ESC
Coding: 517E4098256984828A7D027AA48A21E679F100 (hex)
Fault codes:
Instrument cluster
Part #: 7E0920970S
Component: KOMBI
Coding: 750B010300 (hex)
[No fault codes]
Airbags
Part #: 7E0959655G
Component: VW10Airbag021
Coding: 000000000000000000000000000000003231 (hex)
[No fault codes]
Steering angle
[ECU not present]
Parking/steering assist
Part #: 7E0919475T
Component: PARKHILFE 4K
Coding: 108008 (hex)
[No fault codes]
Heater & air conditioning
Part #: 7E0907047AK
Component: Climatic-T5
Coding: 0000000003 (hex)
[No fault codes]
Central electronics
Part #: 7E0937090C
Component: BCM PQ25 Max4
Coding: B9AC39BA0A63341193284FF47EEB9E740F84710F60EC6960330400230840 (hex)
[No fault codes]
CAN network gateway
Part #: 7E0909901
Component: GW-K-CAN TP20
Coding: 042305 (hex)
Fault codes:
Immobilizer
Part #: 5K0953234
Component: IMMO
Coding: 000000 (hex)
[No fault codes]
Adaptive cruise control
Part #: 7N0907572C
Component: ACC Bosch PQx
Coding: 00004000FE0779 (hex)
Fault codes:
01058 Function - Constant Charge - Current
01059 Rotor Position Sensor (G159)
00274 ABS Outlet Valve - Left Rear (N134)
Battery regulator
Part #: 7E0907534
Component: Batt.regelung
Coding: 030B7A73 (hex)
[No fault codes]
Infotainment system
Part #: 1K8035150L
Component: MU-E-D-ER
Coding: 065700003C00000041111101008000001F0000C60000010001 (hex)
[No fault codes]
Fault codes
25809
25126
Engine
Part #: 04L906056KA
Fault codes:
ABS
Part #: 7E0907379P
Component: ESC
Fault codes:
Instrument cluster
Part #: 7E0920970S
Component: KOMBI
[No fault codes]
Airbags
Part #: 7E0959655G
[No fault codes]
Steering angle
[ECU not present]
Part #: 7E0919475T
[No fault codes]
Part #: 7E0907047AK
[No fault codes]
Central electronics
Part #: 7E0937090C
[No fault codes]
CAN network gateway
Part #: 7E0909901
Fault codes:
Immobilizer
Part #: 5K0953234
Component: IMMO
[No fault codes]
Part #: 7N0907572C
Fault codes:
Battery regulator
Part #: 7E0907534
[No fault codes]
Infotainment system
Part #: 1K8035150L
[No fault codes]
