Thanks - intriguing... I believe I'm catching up...
A VCDS scan of a similar is most likely this:
Address 08: Auto HVAC (J301) Labels:* None
Part No SW: 7LA 907 426 E HW: 7LA 907 426 E
Component: AC Manuell H01 0602
Rear A/C Control Head 1:
Subsystem 1 - Part No SW: 7LA 907 049 D HW: 7LA 907 049 D
Component: E857 H02 0301
Rear A/C control head:
The "E857" can be even traced back to the wiring diagram.
I believe the correct wiring diagran for this system is actually
Manually controlled heater, 2nd heat exchanger with passenger compartment ventilation, air recirculation via headliner with air conditioner ducts wiring diagram VIP Membership is required to download this document
www.t6forum.com
although it's not really different re the externals - e.g. wiring.
The circulation pump would be fed through red 17 pin connector under left seat. However, I can't see the fault - blank control panel & rear blower- being there.
The overhead control panel E857 has no connections under left seat (see page 21/3 in wiring diagram) - just sharing fuse SC12 with main AC controller EX21. The connection between E857 and EX21 is via coupling point TCPM in dash centre.
The rear blower V80 is wired under right seat, coupling point TSKVR, red 17-pin connector.
