Help! Trim under dash below headlight switch
JiMsHaDY69
Stumped on how the trim panel below the headlight switch is refitted?
My issue is getting the trim under and around the circular headlight switch as the the courtesy light brightness/passengers on board switch stops the trim going in under the circular switch.
Couldn't find anything relevant from searching here or on YouTube.
Is there a knack to this that I'm just missing?
Image below to show area trim was removed from.
Thanks in advance for any help.
Thanks @Peatey I will have a look for the torx screw tomorrow as I had my fill of it not going back on despite my best attempts and walked away before it spoiled my day.
What @Peatey said. Remove the switch remove the torx screw then unclog the bezel. Refit the trim first, then the bezel and the switch.
Can you not take the switch out (turn to auto and pull then theres a torx screw to release the bezel) if I remember right
Agreed as I had my switch and lower dash removed this morning. Torx screw behind the light switch at 12oclock. Then the switch surround will come out with a little persuasion.
