Help With Some Dtc's/fault Codes On Obdeleven
tintim
120,000 miles and still going
Hello
Little help with some fault codes that keep appearing.
3rd one is new! Anything to be concerned about? Thanks
01 Engine
System description: R4 2,0L EDC
Software number: 03L906019GQ
Software version: 8440
Hardware number: 03L907309L
Hardware version: H38
Serial number: 00000000000000
ODX name: EV_ECM20TDI01103L906019GQ
ODX version: 003006
Long coding: 01194012232401080000
Trouble codes:
U100800 - Diagnostic interface for data bus Read out DTC
Intermittent
09 Central Electrics
System description: BCM PQ25 Max4
Software number: 7E0937090
Software version: 0736
Hardware number: 7E0937090
Hardware version: H80
Serial number: 0771 316152325
Long coding: B9A439B84A63349193284FF46CEB9E708FA0710F60CC6D60320400230800
Subsystems:
System description: RLS 211115 03
Software number: 5K7955559B
Software version: 0059
Hardware version: 37
Long coding: 0228EE
System description: J386__TSG_FT
Software number: 7E0959801K
Software version: 8654
Hardware version: 003
Serial number: KU0KU004111553087952
Long coding: 1400B0
System description: J387__TSG_BT
Software number: 7E0959802K
Serial number: KU0KU005111553090354
Long coding: 0400A0
System description: DWA-Sensor 00
Software number: 7E1951172
Software version: 0104
Hardware version: 001
Long coding: 000000
System description: LIN BACKUP HO
Software number: 1K0951605C
Software version: 1501
Hardware version: H05
Long coding: 000000
Long coding: 000000
System description: E221__MFL-DC1
Software number: 2H0959442
Software version: 0103
Hardware version: H02
Serial number: 29150002099530025451
Long coding: A4FFFF
Trouble codes:
03022 - Local data bus 4 Electrical malfunction in circuit
static
19 Gateway
System description: GW-K-CAN TP20
Software number: 7E0909901
Long coding: 042307
Trouble codes:
03713 - Control module for hybrid battery management No signal/communication
static
Hello
01 Engine
ODX version: 003006
Trouble codes:
Intermittent
Subsystems:
Long coding: 0228EE
Long coding: 1400B0
Long coding: 0400A0
Long coding: 000000
Long coding: 000000
Long coding: 000000
Long coding: A4FFFF
Trouble codes:
static
19 Gateway
Long coding: 042307
Trouble codes:
static
Not much information in the codes. The first one (the engine) suggests that there is some kind of intermittent network problem. I would think that's the one which needs attention first.
Any modifications/repairs/replacements on the van?
I always thought it was OBD2... Have I missed the other 9 version changes?
I've only had the van about three months. No mods to the engine as far as I'm aware.
I have noticed the rear lid not opening sometimes when trying to open manually.
Strange. Has the battery been replaced recently?
Noticed that you had mentioned elsewhere non-working start-stop system. Engine not communicating properly probably would be a good reason for that. The gateway 19 is centre point of van's internal communication and now the gateway and the engine are reporting databus problem - something somewhere is not perfectly right.
I understood that the faults have reappeared after clearing them? Btw, is it a DSG van?
Have you tried to read fault codes individually from control units - especially the following: 01, 09, 17, 19, 61? Could you check the history in control unit 01 (engine) - is the fault characterized as active or inactive?
Same AGM battery from when the van was new
I will raise the fault with the Van seller as I'm still (just under warranty)
Yep the first two keep coming back. Its a manual
I'll check the history and get back, I do recall the amount of times they have happened is quite high.
Thanks for helping, plenty for me to do/research
