transporta
Having an issue with a October 2017 DSG T6 going into drive when first starting, you need to wait for 3-4-5 seconds then you touch the throttle and boom it jumps in with a clunk, it doesn’t feel good at all. Seems to go into reverse no problems. DSG oil has been replaced and looked very clean when dropped but the issue was there before the change. It’s only happened with a clunk a few times but it usually hesitates, sometimes longer than others, once warm things seem ok although the shifts are not always as smooth as other DSGs I’ve driven in non van cars. DMF is also on the way out but that seems like a separate issue. Has anyone had the same issue? I’m planning on taking it into the dealership for diagnosis but as it’s out of warranty I’m not really keen to just write the dealer a blank check, so I’m hoping to get some info before hand. Has anyone had any luck out of warranty period? I have heard of a few stories of people getting work down after the warranty has ended. the car only has 90k km.
Any advice would be appreciated.
