High Idle Speed
dicey price 123
Hi all, my 66 Plate Highline sometimes idle at 1000 rpm not the usual 900... then on another day will at 900 and rise to 1000 when put into gear for driving as normal. Any ideas please??
Rich
Hi everybody
I have got the same problem never no what its running at could be 850 rpm or 900 rpm or 1000rpm when it's at 1000 if I switch the engine of it starts backup at 900rpm and stays there ? Ps it's still under warranty stop start not worked since October ad it back to Preston they said it's fine can't find a fault
Disappointed T6 owner
Hi everybody
850 rpm, 900 rpm or 1000rpm is not a problem . . . . thats normal operation, The engine ECU decides what rpm to run the engine at depending on the situation.
the fact you say the the stop/start hasnt been working for a while indicates that you are not doing long-enough journeys to replenish the energy drained from your starter battery on a daily basis.
higher rpm`s like the 950/100 are normally due to cold weather, regen, high electrical demand or low battery SOC.
Possible dodgy battery killing the stop/start function, seems to be an ongoing thing with Moll EFB batteries lately
Hi everybody
Hi
Thanks for all your time it Was October I took it for a good run as for the idle I just have to live with it thanks again for your comments
Kind regards
Springbox
Jumping onto an old thread here.
I too notice ideal at 1000rmp, seems normal reading this thread.
But is regen phase?
cleaning up the DPF . . .
More info here:
More info here:
Oh right! Quite technical.
Thanks for that.
