Sadly I have had a bit of a van disaster (at just under 50000 miles)- as diagnosed by VW, the high pressure fuel pump has failed putting swarf into the fuel system. VW have recommended complete replacement of the fuel system including pump, fuel rail, pipes, injectors etc at a total cost of (gulp) 7k. From googling this seems to be a recognised (if uncommon) problem which always has a mega bill attached. I don't have any warranty so no real alternative other than cough up.
I'm racking my brains for a reason this couldve happened as I am paranoid if it happened once it could happen again. Apparently misfueling is a reason but I have definitely not put petrol in my van. The van was remapped by a previous owner from I believe 102 to 140bhp. It has been suggested to me that this might have been putting additional stress on the fuel pump causing it to fail.
Can anyone tell me is this theory likely, or should the pump be able to cope with this? Is the fuel pump in the higher HP engines the same or different to the lower ones? If this had happened to your van would you get the map reversed? Ta
