Hob Issue
Steved55
Hi all - I've got a standard two burner hob set up which has previously been faultless. Came to make a brew tonight after a walk in the peak district - hob had not been used for weeks and gas had been isolated at the locker - pressed the knob down and pushed ignition - loud pop and smell of singing as fireball erupted!
Switched off, turned on gas for a few seconds with no ignition - sounded normal so after venting the van tried again and it ran as normal.
Is it possible I somehow got liquid rather than gas at the burner? It's about 2c at the moment.
Any hints welcomed!
Any hints welcomed!
butane does not gasify if thats the right spelling at that temperature it stays liquid
Any hints welcomed!
